A plastic flat plate could be used that attached in front and behind the servo using existing chassis servo holes. It could have countersink holes to the sides that allow using standard servo mount blocks. Or the plate could have brackets that fit around the servo mount flanges and a top strap to hold the servo if. Either is simple enough to do. Once the servo is installed, you would find out if the steering needs full left and right throw or not. Many of my buggies end up with only 70 - 75% needed before the steering blocks are at full limits.
Attaching Steering Servos to a rc10 pan chassis
- Frankentruck
- Has thanked: 1590 times
- Been thanked: 1773 times
Re: Attaching Steering Servos to a rc10 pan chassis
- Has thanked: 1013 times
- Been thanked: 472 times
It looks like a bigger challenge is the steering arm hitting the chassis. The biggest challenge is getting a decent block of time to assemble this.Frankentruck wrote: ↑Mon Aug 14, 2023 9:23 am A plastic flat plate could be used that attached in front and behind the servo using existing chassis servo holes. It could have countersink holes to the sides that allow using standard servo mount blocks. Or the plate could have brackets that fit around the servo mount flanges and a top strap to hold the servo if. Either is simple enough to do. Once the servo is installed, you would find out if the steering needs full left and right throw or not. Many of my buggies end up with only 70 - 75% needed before the steering blocks are at full limits.
- Lowgear
- Has thanked: 78 times
- Been thanked: 597 times
Likely because the pics JosephS uploaded are all too small.MarkyDents wrote: ↑Sun Aug 13, 2023 11:16 pm Argggg I want to click the pics for clarity but it won’t work…. Why does this happen sometimes !?!
Last post I made with a couple pics the last one did this. I know I placed them all inline in the single post
I blame iOS, for giving me the options. I'll see about posting up bigger ones to the original post.Lowgear wrote: ↑Mon Aug 14, 2023 3:18 pmLikely because the pics JosephS uploaded are all too small.MarkyDents wrote: ↑Sun Aug 13, 2023 11:16 pm Argggg I want to click the pics for clarity but it won’t work…. Why does this happen sometimes !?!
- 44 Replies
- 5274 Views
Last post by CAT3K
- 5194 Views
Last post by Frankentruck
- 1575 Views
Last post by njdriver04
- 637 Views
Last post by THEYTOOKMYTHUMB
- 22 Replies
- 589 Views
Last post by duckhead
- 1773 Views
Last post by Dave145
- 1475 Views
Last post by janaya
- 790 Views
Users browsing this forum: Haggy38 and 10 guests
