So, what did you do RC today?
- Has thanked: 1032 times
- Been thanked: 488 times
I finally painted my ProCat, or at least started on it. I spent the last few months dreaming up cool schemes worthy of its futuristic shape, then remembering that there was no way in @#$% I could pull them off with my painting skills. Yesterday I decided to stop torturing myself and just spray the stupid thing white.
- Frankentruck
- Has thanked: 1589 times
- Been thanked: 1770 times
Just need a good supply of stickers
- Has thanked: 65 times
- Been thanked: 46 times
- TRX-1-3
- Has thanked: 1399 times
- Been thanked: 764 times
After putting the little one on the bus to school this morning I took an old clod body I have and sprayed it with easy off and bagged it. Hope I can get it back to white so I can paint it the right way not the lunchbox yellow it was.
- Has thanked: 22 times
- Been thanked: 21 times
Swapped the laydown for a layback transmission. Hoping I like it better.
- silvertriple
- Has thanked: 593 times
- Been thanked: 860 times
Finished quite a few projects with the last details added...
- TRX-1-3
Getting there.
Also modified a TRX-1 front tower (bottom) to fit a "TRX-2" bulkhead. Lots of filing
Upon test-fitting, it was realized that the shock angle is jacked using TRX-1 arms. So it's either TRX-3 arms or I shim the shock tower rearward on the bulkhead. Leaning towards shimming. Have a sacrificial tower, just gotta hack it up!Hope you're doin' something fun.
- R6cowboy
- Has thanked: 518 times
- Been thanked: 554 times
Cleaned, rebuilt and tested some Reedy motors today. Tri-Sonic "Y" 10x3 w/6* deg, Tri-Sonic "C" 13x3 w/6* deg, Firehawk 27x1 24* deg. stock (now with bearings), Krypton 10x2 w/6* deg, Krypton 7x1 w/6* deg (no label), Titanium 10x2 w/6* deg, and Platinum 12x1 w/6* deg.
-Jerry-
Broke a bulkhead on the B4 from a weak slap to the wall at the end of a straight. Thankfully, had a spare plastic one. Ordered an aluminum bulkhead.
The B6 is going back to lay down transmission. It was tail happy and hard to control with the layback.
- juicedcoupe
- Has thanked: 231 times
- Been thanked: 1747 times
Put some more AmPro parts on the Brat. Added the shock mount / body mount braces. I also switched the rear tires for some Trenchers.
I mounted the ProCAT body. The completely uninspired paint choice looks OK. The only hint of color is the Factory Works decal. I used Jeff's XLS chassis on this buggy, otherwise it is a kit standard re-re.
- 695 Views
Last post by Dr. Robotnik
- 1180 Views
Last post by Synergy
- 1337 Views
Last post by Lowgear
- 1533 Views
Last post by ireg
- 32 Replies
- 4871 Views
Last post by uniquenamehere
- 978 Views
Last post by Halgar
- 2705 Views
Last post by walfre
- 5686 Replies
- 418692 Views
Last post by Frankentruck
Users browsing this forum: No registered users and 22 guests
