Scorpion 4x4 Build project
- Has thanked: 2287 times
- Been thanked: 1994 times
Re: Scorpion 4x4 Build project
I hope my last post didn't sound dismissive of people working with more basic tools , I'm in awe of what 1300GT achieved with basic tools on his 4wd SRB custom build ,that was the inspiration for this car in the first place .
Anyway i finished the the second king pin this evening so it's just the second drive shaft to extend (I've made a sleeve and have the silver solder ready ) then it's steering time , i think i know what I'm going to do .
Today I extended the second drive shaft and silver soldered the sleeves , after fitting and testing i was still worried that they might pop out at full lock so i decided to add springs in the diff drive cups , those drive cups are supprisingly hard steel ! I had to deepen them to make space for the springs and the only thing i had that would touch them was diamond dust dremmel tools ,took a little time but it worked and the shafts are now satisfyingly secure , they even click into place when fitting them so I'm a happy man and i can move onto the steering.
I had a little time this afternoon so made up the chain guide pulleys , i also removed a single chain link and i think i got lucky as the tension is just about spot on i can still add a tensioner at a later date if it's needed ,pictures later .
Pictures of the finalised transmission ,drive shafts extended , chain guide pulleys fitted and chain length shortened, there's a second guide pulley up front but its kind of hidden , you can see the screw that it runs on in the side of the tub in the second picture also a scratch in the tub i'll have to clean up before painting:(.
I made a start on the steering this evening , it's going to be tight but i think its going to work , looks like I'll have minimal bump steer if all goes well .
I got started on the steering system , there are a few areas that need attention as yet , i have a slight binding issue on the track rod ends with suspension compressed but i have a couple of ideas to overcome it , clearance is tight as the links go under the diff out drive cups and there's only 3mm so they are just over 2.5mm thick , bump steer is acceptable and probably less than stock , its not clear in the pictures I'm afraid , the top part of the top crank for the linkage is over size at the moment as i was not sure of the relative alignment of the top and bottom arms as its not 90 degrees so i thought I'd fit it and then mark the position for cutting later .
the really good news is that it all fits under the body.
- Lonestar
- Has thanked: 626 times
- Been thanked: 166 times
I can't wait to see this thing finished
I had thought of a top arm , easy enough to do by replacing the top link mount and making a top arm mount,as it is i should really make a taller mount to raise the ball joint as the steering hub is taller than the 2wd version anyway , it would also reduce the load on the flanged bearings in the king pin assembly , i have to admit to being worried about the 6mm flanged bearings not lasting too long but the move to double trailing arms is a big cosmetic change from standard that I'm reluctant to make , what i may do is go to 7mm flanged bearings and make a slightly bigger king pin assembly , there's space to do it and it would be all up stronger with possibly less play .
- Been thanked: 288 times
You could narrow your track a few more millimeters...Kyosho made some hexes that were 3mm thick, about the thinnest I've seen...they have taper-fit holes for the axles, mind you...you need Optima tapered axles. I wish I could remember the part number! I used a set of those to narrow the track on my CYANide on-road Optima car.
Other than those Kyosho units, the narrowest 12mm hexes I've seen that use cross-pins are 4mm thick. Those are easily available on eBay.
- Been thanked: 10 times
those are for the sp cars and have been used on the front of the lazer zxs / evolutioneCoelacanth wrote: ↑Wed Apr 05, 2017 12:27 am You could narrow your track a few more millimeters...Kyosho made some hexes that were 3mm thick, about the thinnest I've seen...they have taper-fit holes for the axles, mind you...you need Optima tapered axles. I wish I could remember the part number! I used a set of those to narrow the track on my CYANide on-road Optima car.
and the part number is sp-62
mvh isobarik
If i need to i can mill a couple of mm off the hexes that are on there , I'm going to have to remove the blue anodising as it's glaring at me as not looking right .
I've ordered up a set of Schumacher full spike tyres as they look fairly retro in a 2.2 size .
She went for a brief test run this evening , there are two little issues .
1 it has the turning circle of an ocean liner .
2 There is a little clearance issue with the chain .
I was kind of expecting the poor turning circle and have a cure , I'm going to drill and tap the steering hubs so i can fit the ball studs for the track rods closer in ,this will increase the turning angle ,probably increase it too much but i can reduce it by end point adjustment.
The chain clearance will be easy ,either adjustment or removing a little material .
This sounds bad but this is the kind of stuff you have to expect in a project like this , I'm actually pretty chuffed that it worked as well as it did first time out .
- 72 Replies
- 10064 Views
Last post by ron
- 2033 Views
Last post by martinthegenius
- 861 Views
Last post by Mr. ED
- 20 Replies
- 2010 Views
Last post by 1300GT
- 1049 Views
Last post by silvertriple
- 66 Replies
- 5916 Views
Last post by SMOKE-DOG
- 570 Views
Last post by DennisM
- 3895 Views
Last post by mjtown
Users browsing this forum: DotNetDotCom.org [Bot] and 16 guests
