I used to do CNC waterjet cutting and I can tell you stainless was by far the hardest material we ever cut. And occasionally we had to tap certain parts. Long days running the machines and many broken taps on 316 and 308 stainless.jwscab wrote: ↑Thu Aug 10, 2017 8:11 am stainless in general sucks to machine depending on the geometry, so i can see tapping being a b!tch. I believe from shapeways it says they use 420 stainless powder, it may be somewhat hard depending on how it was created. Then then take that stainless and somehow infuse it with bronze. bronze can be tricky to machine also.
3D Printed Stainless Steel Outdrives
- Been thanked: 19 times
Re: 3D Printed Stainless Steel Outdrives
Current:RC10T, T3 FT, GT Blue Tub, GT FT, GT2 FT, GT5, RC28, SC28, Micro RS4.
Previous:B2, B3, B3 FT, 10T pink chassis, GT FT, TC3, TC3 FT, RS4MT
Tamiya TA02, Thunder Tiger TS4N pro, Kyosho VoneR, Emaxx, MX4, MP 7.5, 7.5 Kanai.
- Phin
- Has thanked: 61 times
- Been thanked: 182 times
Using the SC10 diff gear would run into one of the problems the MIP Changebox transmission had...the larger 52T gear raises the outdrives and the drive shafts become too short. If you went that route you might also need to make taller axle hubs like the RPM GT or Losi JRX Pro to compensate.
- mk-Zero
- Business Member
- Has thanked: 4 times
Good to know. We could use longer CVA's too though. The Worlds ones are too short already even with a Stealth diff.
- mk-Zero
- Business Member
Shapeways says +/- 5% + 1 layer, so as far out as some of the features are, they are within their stated tolerance. I will probably adjust the models some though, and then ideally just clean them up on the mill and lathe.
Tonight I got them all sorted out except the drive pin slots. Those were my mistake, I accidentally made the slots .080" wide, should have been .104", but then they printed undersized on top of that, at like .070". I had to order an end mill bit to slot them, it's arriving tomorrow. And last night I made a fixture to hold them in my mill vise.
Everything except the slots fixed By this weekend I will have the slots fixed and have them in my RC10M, and then I'll abuse them on the street and see how they hold up. Then we'll go from there.
- NomadRacer
- Has thanked: 83 times
- Been thanked: 77 times
- mk-Zero
- Business Member
If these work okay on my car, maybe I'll get a couple sets out there to some willing beta testers
- lmw94002
- Been thanked: 6 times
If they work, i'd be up for a set or two... cause I have a pair of transmissions to rebuild with absolutely shredded outdrives.
--Builds--
--Builds--
- mk-Zero
- Business Member
So tonight I machined out the grooves. The bones fit in them really nice now and spin and articulate smoothly.
Then I went a head and assembled the diff. Went together nicely. The feel is a little inconsistent, I think I am going to need to flatten out the raised areas that the drive rings sit on. That will be easy once I have my lathe.
In the mean time, I'll put this diff in the car and start abusing them, see what they do.
- lmw94002
Looks good!
--Builds--
--Builds--
- jcwrks
- Has thanked: 121 times
- Been thanked: 259 times
A complete stealth diff is available on eBay if anyone needs the outdrives.
http://www.ebay.com/itm/Vintage-Team-Associated-Rc10-ball-diff-/232470174458
The official TX SKUNK
- mk-Zero
- Business Member
And he's got 2 of them!
Tonight I plan to swap the diff I built with the printed outdrives into my RC10M and then take it to the track tomorrow to abuse. I'll report back my findings.
On another note, I am now the proud owner of a 7x12 lathe, so if the printed outdrives end up working I'll be able to machine them to spec pretty easily and supply them to you guys. I may also buy a set of b4 outdrives and turn them down, just to try it.
- Has thanked: 10 times
- Been thanked: 447 times
BTW, here is a crappy pic I posted a while back when there was a shortage before the re-re of the B4 parts machined.
- Attachments
- outdrive_machined_b4_for_stealth.jpg (42.52 KiB) Viewed 1754 times
- Has thanked: 135 times
- Been thanked: 23 times
Or lower the diff., similar to the B2 or like losi did with a recess in the chassis.
- 592 Views
Last post by aesalazar
- 1672 Views
- 438 Views
Last post by badhoopty
- 475 Views
Last post by juicedcoupe
- 762 Views
Last post by Vand_rc
- 131 Views
Last post by Bottom Feeder
- 2123 Views
- 603 Views
Users browsing this forum: Facebook [Bot] and 40 guests
