I may or may not be building one of these(look for a thread soon ). Are the rear shock spacer settings designed to use the 1.32" shock shafts?
Also, just from an eyeball, it looks like the steering bellcranks can contact the arms on the lower inner hinge area when the arms are compressed upwards and the steering is turned towards the arm. I don't have the shocks installed to see where they create a hard stop, but has anyone else seen contact in this area?
has there been a post that explained the upper and steering link lengths, ball center to center? I remember someone mentioning some weird bump steer and that the link lengths were critical in this area.
NIX91 Questions and Answers
Moderator: Seabass
- Niki
- Has thanked: 3 times
- Been thanked: 36 times
Re: NIX91 Questions and Answers
Hey,
Yes, 1.32" shock shaft. I used one 1/8" spacer inside the shock.
Seabass wrote: ↑Mon Dec 01, 2014 8:36 pmDavid this was actually an issue that was found on the original car. if you look at some of the pictures, you can see where the front arms were ground down in the same area you are having a problem with. The issue is that the front is really cramped for space. You will find that car has quite a bit of steering and depending on your track or driving style, you may need to take some of the steering out of the car.dj_kilroy wrote:Hey there,
I've just finished putting my car together and noticed that with the race arms front arms and steering, there isn't any clearance for the steering cranks when the suspension is compressed. Should I shim the steering upwards and has anyone else thought that this is an issue?
Post up some pics once you get it going.
Jake
Niki wrote: ↑Sat Nov 08, 2014 6:21 pmSounds interesting as I can't see the problem in my runner.slotcarrod wrote:So I mock fitted up my car and wow the bump steer is huge. Any suggestions?
After tuning the 3d-model with my current real car setup - teoretical measurement for bump in was 1.2 deg when chassis touches the ground (25deg arm travel). With the real car I had hard time seeing anything.
Bellcrank link = 38.5mm
Steering link = 72.8mm
Camber link = 64.1mm
Bump steer spacers = 3x0.8mm
When adding lenght to bellcrank link and bump steer spacers, zero deg bump in can be reached easily.
NIXconcepts -Shapeways Shop- -I.materialise Shop-
--- Quadra-symmetric RC10 --- RC10 '91 Worlds Conversion --- Start of NIX91 story...
Anyone heard anything if either the aluminum or carbon fibre chassis kits will be available again?
Update: negotiations in the works....soon!
I killed an Edinger...the shame
- XLR8
- Has thanked: 1237 times
- Been thanked: 890 times
- 670 Views
Last post by Y'ernat Al
- 643 Views
Last post by Doc J33P
- 1305 Views
Last post by olderacer
- 994 Views
Last post by Mark Westerfield
- 45 Replies
- 13743 Views
Last post by Niki
- 35 Replies
- 11750 Views
Last post by Lurker
- 59 Replies
- 9580 Views
- 4010 Views
Last post by DMAT
