- klavy69
- Moderator
- Has thanked: 561 times
- Been thanked: 265 times
tires look like the proline razor backs. Not a big tamiya guy but maybe like a hornet or a frog wheel?
- dave00beer
- Has thanked: 9 times
Well they were on a super champ I recently inquired, Just don't look like the common "open spoked" style Tamiya wheels that were run on various models. And yes those are some old razorbacks.
- dave00beer
- Has thanked: 13 times
- Been thanked: 78 times
BBS style wheels which I received some years ago, but never found which car they go for. Could be 1/10 or 1/8 scale.
Diameter is around 51.5 mm, wide is 31 mm fronts and 50 mm rears. Bearing size seems 10mm fronts. I thought maybe for one of the MRP electric cars but not sure. Someone have an idea?
- Basher67
- Has thanked: 44 times
- Been thanked: 154 times
Got a pile of old AE parts and there's a few I can't nail down the i.d. on. The pile was a mix of RC200, RC300 and RC500 parts with some early 1/12 parts thrown in. I got most of it sorted and figured out, but can't seem to confirm what these parts are for.
- Basher67
I also came up with these Trinity king pins. No idea what they fit after searching the web everywhere I could think of.
- Basher67
Ok, I found a parts list to verify the AE onroad parts above. I don't know why I couldn't find it last night. I added a pic of the Trinity kingpins also. Might make it easier to i.d.
- matt1ptkn
- Has thanked: 80 times
- Been thanked: 132 times
I've got several items here that I am not able to narrow down. If anyone can help ID anything, please let me know. Thanks in advance!
- Attachments
Matt
- Has thanked: 10 times
- Been thanked: 447 times
I believe the top diff is for a kyosho model, I just modified a pair of diff hubs for Jeremy that looked identical. I think thorp would be a split hub design with three screws. see this info:
https://www.rc10talk.com/viewtopic.php?f=82&t=43787
the white gear diff below that looks like a traxxas design.
the U shaped black shock tower is yokomo 870c
- matt1ptkn
The diff does look very similar to the one in the topic you shared. However, it appears that one allows the removal of the drive cups; the one I have the drive cups are one piece with the outdrives/axles. Maybe a running change? Thanks for your reply!jwscab wrote: ↑Wed Feb 27, 2019 12:07 pm I believe the top diff is for a kyosho model, I just modified a pair of diff hubs for Jeremy that looked identical. I think thorp would be a split hub design with three screws. see this info:
Matt
- matt1ptkn
Also found this motor. I figured with the manufacturer name on the end, it'd be easy to find info. But that is not the case. Its a 540 size.
Matt
- Regular Member
Morning all, trying to figure out what this truck or buggy is. Hours of googling and I’m not seeing anything with that front shock setup and chassis bracing.
Anybody have any idea?
- 59 Replies
- 8638 Views
Last post by Diamond Dave
- 102 Replies
- 15635 Views
Last post by mikesofunny
- 431 Replies
- 39489 Views
Last post by Eccentric
- 67 Replies
- 8959 Views
Last post by bearrickster
- 448 Replies
- 35988 Views
Last post by MelvinsArmy
- 321 Replies
- 27890 Views
Last post by tazz888
- 351 Replies
- 34733 Views
Last post by Frankentruck
- 2205 Views
Last post by mrlexan
