Anything that fits in the stock transmission should fit in this, this is a direct replacement for the stock case.
The ultimate Mini JRX2 thread
- Has thanked: 100 times
- Been thanked: 206 times
Re: The ultimate Mini JRX2 thread
Mini - T, LST, LST2, Crawler
Micro - Trekker, SCT, T
Just thought I would park this here heh.
- Has thanked: 7 times
- Been thanked: 11 times
It was a general question, not specifically about your case. I know the diff doesn't work due to the different axles.
I am going to start printing some H arms tonight however!
Why thank you sir, and yeah top shaft is same part number between the two models.
I just had a though about the bodies we are needing, what if we take a 3d scan of the uncut 10th scale body and size them appropriately? This is about the only place a 3d scan might work for making these parts
That would be awesome. The Mini Jrx2 body seriously irritates me. The windshield is so wide. I was going to pour plaster into the body, reshape it and then pop out a proper body from my cheesy vacuum table. Then I wanted to order proper decals that don't say Mini on them.
Working on another missing piece for replicating other models.. I have 1 and 2 modeled already, still need to do 3 and 4.
Yogurt from Spaceballs says: "Upsee-dahzee, upsee-mahzee, upsy-daisy!"
The files have been uploaded, I have tried to replicate the precision of the rear toe blocks as close as I possibly can, #1 would be the 'stock' one to use as a stock build with the H arms. I would (and have) oriented them with the numbers facing up when printing with a hot .2 nozzle.
Rear Toe Blocks: https://cults3d.com/en/3d-model/game/losi-a2016-rear-pivot-support-set-for-mini-jrx2
Chris
Chris
If anyone has already smoked your tires and replaced them to something new, I am looking for some used wheels for destructive disassembly so I can model some logo wheels correctly!
Just did this up for a reference as there is no listing anywhere. This is not all the screws, but it is good for basic reference.
side bulkhead to chassis m2x8 flat head
link to side bulkhead/rear carrier m2x8 socket head
battery box to chassis m2x8 flat head
battery box hinge m2x10 socket head
antenna mount m2x8 flat head
servo to mount m2x8 socket head
servo mount to chassis m2x8 flat head
bellcrank post to chassis m2x8 flat head
front bulkhead to chassis m2x6 flat head
front shock tower to bulkhead m2x8 socket head
both shock upper mount m2x14 socket head
front shock lower mount m2x10 socket head
rear shocktower to bulkhead m2x6 socket head
rear bulkhead to chassis m2x8 flat head
gearbox to chassis m2x8 flat head
motor plate to chassis m2x4 flat head
Well that doesn't look like a Losi part... Hmm.
- sandkil
- Has thanked: 670 times
- Been thanked: 462 times
So I couldent resist.
I bought the red one, Figured as it's my first ever Losi!..
I have a few mods in mind.
Swapping the wheel nuts for white nylone.
Thinking of painting the receiver/esc case orange.
Try to source mini-T 1.0 springs.
I've ordered JRX2 decals and panel decals in 1/16 scale from MCI. We'll see how they fit.
Ordered 1,5 mm Kydex for a front bumper.
will order 1,3 mm piano wire for proper wing mount.
And the Reedy Mini Mod 19T. Looks so much better with a open end-bell. I know it's not a Losi or Trinity motor, but i got a good deal on it.
- sandkil
Update on the 1/16 scale Team Losi JRX2.
Painted the rx/esc orange. Was not able to swap the negative motor wire to a blue one as the rx/esc is filled with epoxy.
Deans conector.
Fabricated a front bumper out of 1.5 millimeter Kydex.
White nylon wheel nuts.
And a couple of stickers.
I figure the chassis is done. Moving on to body and wing
Deans conector.
- RogueIV
- Has thanked: 1119 times
- Been thanked: 459 times
Great work Chris! I hadn't seen this post but I originally planned on making a replica of my first Truck: an LXT with a JRX chassis, Looks like you beat me to the punch with making the models though! I guess I shouldn't have procrastinated on picking up the Mini JRX2. I may pick up a few more of these later to do different variants too. My first R/C was a used JRX Pro SE which i might want to replicate later but I unfortunately don't own that car anymore.
I am going to shift my model focus to some cosmetics for now. Like a dummy Hydra-drive to cover up the outside slipper assembly.
That and figuring out ways to tighten up the front. Seems Losi uses undersized hinge pins so there's a lot of slop up front especially at the castor blocks. Already fixed a bunch of slop in the steering by using a bunch of shims on the belcranks and tighten up the rear a bit shims as well.
- dldiaz
- Has thanked: 14 times
- Been thanked: 34 times
Hello sandkil,
Can you give some details - brand / part number - for the white nylon wheel nuts you used?
Thanks!
-dldiaz
- 37 Replies
- 12206 Views
Last post by jcwrks
- 780 Views
Last post by JK Racing
- 1377 Views
Last post by mtbkym01
- 31 Replies
- 4789 Views
Last post by Lavigna
- 1679 Views
Last post by RC10th
- 225 Views
Last post by isaidme
- 28 Replies
- 2189 Views
Last post by Heffay
- 90 Replies
- 12287 Views
Last post by huminski
Users browsing this forum: No registered users and 19 guests
