The RC Corvette in - (1988) The Dead Pool - Clint Eastwood
GreenBar0n
Has thanked: 578 times
Been thanked: 262 times
Re: The RC Corvette in - (1988) The Dead Pool - Clint Eastwood
Post by GreenBar0n »
scr8p wrote: Wed Jan 17, 2024 6:38 pm It's a Parma body.
I found an eBay auction with a poorly painted Parma 63 vette body. If the line on the roof of the Bolink, or TBG 63 vette is the only wrong thing, I'm ok with that compared to this - not just the color, the mold looks not as crisp or detailed:
https://www.ebay.com/itm/175547337083
GreenBar0n
limestang wrote: Wed Jan 17, 2024 7:01 pm After looking at pictures and reading numerous posts, here’s my best estimate on the wheels:
Rear - 1.5” OD, 1.3” Width, 0.15” Negative Offset, Foam Tires
Front - 1.5” OD, 0.7” Width, 0.19” Negative Offset, Foam Tires with 4 grooves
Does this seem reasonable? Hopefully I calculated the offset correctly. It appears same as factory 3 piece wheels.
Thanks, limestang
Many thanks for this @limestang, I will be certain to have this figured out before D-Hawk cuts them.
romulus22
Has thanked: 665 times
Been thanked: 662 times
Post by romulus22 »
Frankentruck wrote: Wed Jan 17, 2024 6:52 pm Blue Groove body has the roof ridge.
Correct, the Deadpool body does not.
Phin
Has thanked: 61 times
Been thanked: 182 times
Post by Phin »
Thanks, limestang
These are the correct wheels from the Advance catalog page above.
So the rears are 1.6" OD one piece wheels (no hub adapter)...and the fronts are also one piece wheels and should have an OD of ~1.7" because they were meant for 1.5" ID tires with the inner bead cut out. The fronts also use RC10 bearings not metric Tamiya ones.
Edit: Also there should be a "5S" after each part number to signify the number of slots.
GreenBar0n
Phin wrote: Wed Jan 17, 2024 8:10 pm These are the correct wheels from the Advance catalog page above.
Callahan finding the exploded front wheel scene:
Reposting these for reference.
@Phin, to make certain I'm understanding the dimensions completely: The front wheels are 1.7" diameter/no-hub/RC10 bearings - the rear wheels are 1.6" diameter/no-hub/RC10 bearings.
Would you happen to know the width of the front and rear wheels, also? I need to be able to tell the CNC machinist the exact dimensions. Thanks!!
Phin
Post by Phin »
GreenBar0n wrote: Thu Jan 18, 2024 1:24 am @Phin, to make certain I'm understanding the dimensions completely: The front wheels are 1.7" diameter/no-hub/RC10 bearings - the rear wheels are 1.6" diameter/no-hub/RC10 bearings.
Try contacting mrlexan and ask him for the OD and width of these plastic Mini-Mags....they should be the same size: https://www.ebay.com/itm/375023221280?hash=item5751203a20:g:WEsAAOSwzypgIcB0
GreenBar0n
Phin wrote: Thu Jan 18, 2024 8:09 am
Excellent idea! I had seen those nylon wheels in my searches previously. When I looked at their description, the seller noted:
The label states these are for Tamiya sized fronts. Size is 1.625 inches in diameter and 0.75 inches wide.
Would it be safe to assume these dimensions would be the same for the aluminum A10SF-5S fronts, as well?
Would then the rears be twice as wide as the fronts, making the rear's 1.5" wide?
Thanks again @Phin!
Phin
Post by Phin »
Here ya go...MarkyDents has MM wheel dimensions posted here: https://www.rc10talk.com/viewtopic.php?p=521900#p521900
They're the 3 slot version (A10-F3S & R3S) but dimensions should be the same.
GreenBar0n
Phin wrote: Thu Jan 18, 2024 7:20 pm Here ya go...MarkyDents has MM wheel dimensions posted here: https://www.rc10talk.com/viewtopic.php?p=521900#p521900
Doesn't get any better or more clear than that! Huge thanks to @Phin and @MarkyDents!
GreenBar0n
Got confirmation today that the Bolink BL2254, 63 Corvette Coupe bodies will be here next week.
The Parma 63 Corvette body would be the most correct for TDP vette, as I now know, but when I watched the movie as a kid the thing that caught my eye was the wheels and knock offs. If I can get those exact, and then have a 63 vette body with a bit more detail to scale, that would do it for my shelf.
Got the HPI '67 vette body cut out today for my tribute project, have to paint it first, then stick the rear on with ds tape, rear end is perched until then. Thinking Kyosho Fazer FZ02 kit for the chassis on this one.
The '67 will be Tamiya PS-16 Metallic Blue, hope that matches '67 Marina Blue.
The decals for the stinger on the hood are black or red, and I'll need white. Not sure how to make that work yet.
1911Colt
Has thanked: 1032 times
Been thanked: 488 times
Post by 1911Colt »
https://callie-graphics.com/
She makes custom decals. If you ask, she will make them in "reverse", so they go on the inside of the lexan.
GreenBar0n
1911Colt wrote: Fri Jan 19, 2024 9:47 am https://callie-graphics.com/
Thanks a bunch for this! That sounds like the best option, to have a white decal printed. Will do the outside decal, the real one is that way too.
https://callie-graphics.com/pages/custom-work - Checking out the custom option now.
Shouldn't be too difficult:
Thanks again, @1911Colt!
GreenBar0n
@MarkyDents said it was ok to post his excellent pics in here, in relation to the TDP RC vette wheel dimensions, so I can consolidate all of this information in one thread.
Front Wheels
1.7" diameter
0.75"width
Rear Wheels
1.7" diameter
1.35" width
Will probably need to discover the offset somehow still.
I sent all of these pics to D-Hawk, and told them I'm looking for these exact wheels, only with the (5) slots, instead of (3). I'll post back with the cost and time it takes when they reply. Thanks again @MarkyDents, and @Phin!
GreenBar0n
D-Hawk said this is the start of the Chinese New Year, so it might be a bit before they can get started on the wheels.
I asked Mid-America - https://slotcarstore.net/pages/1-10-Car-Bodies-U2679.html - if they would remake the Parma '63 Vette #10218 - AKA The Dead Pool body. I'll report back what they say. Here is the Parma #10218 (pics from Worthpoint):
Was going over The Dead Pool scenes, and saw this on the table in Rook's home:
Cheap '63 Vette RC toy, specifically:
Was on eBay the other day and couldn't believe what I was seeing - just got this for $10!
On Rook's table you can barely see the control box laying upside down behind the toy.
They split the controller in half on the table in the movie:
I was elated.
GreenBar0n
Bolink bodies made it here today.
Test fit the RC10.
This is as good of a fit, or the same as the Parma body it appears.
Comes with window masks, and that's it, no decals.
The line on the roof, and the hood grills are more accurate to a real '63 vette.
Has the same shaped side vents as the Parma.
Nearly same size as HPI '67 Vette.
Got some chrome pens to mark out the window frames, like the movie car.
Tamiya Black spray will be here Monday. Will get this cut out, windows masked, and the window frames chromed before then.
The Bolink looks to be the exact same dimensions as the Parma. I'll paint this up and we'll see.
Post Reply
  • RCCA August 1988 Jay Halsey in The Dead Pool
    by terry.sc » » in Vintage Magazine Articles / Ad Scans
    Last post by RichieRich
  • Tamiya Wild Willy 2 "Clint Eastwood" Edition
    by Rc4on » » in Tamiya Forum
  • DEAD POOL Vette
    by Lou0151 » » in RC10 Buggy Forum
    Last post by Lou0151
  • Project Dead Pool
    by littleVETTE » » in RC10 Buggy Forum
    Last post by juicedcoupe
  • RC10 DS dead pool body ?
    by rctenracer » » in Associated On-Road Forum
    Last post by littleVETTE
  • Vintage RC video footage: Dead pool
    by MOmo » » in Off-Topic / Chit-Chat
    Last post by AMorgan
  • Aussie Alert - The Dead Pool.... on tv TONIGHT!!!!
    by Incredible_Serious » » in Off-Topic / Chit-Chat
  • Franken Dead Pool DS-ish Car, restomod version
    by Frankentruck » » in Associated On-Road Forum
    Last post by Frankentruck
Users browsing this forum: User avatarahenderl and 16 guests
