RC Top Faux Buff CAT 10
- Frankentruck
- Has thanked: 1589 times
- Been thanked: 1770 times
Re: RC Top Faux CAT 10
Next decision is 1/4" CVD or 3/16" CVD. For this build I'm leaning toward 1/4".
- Frankentruck
I also need to decide which gearbox is going in. I kind of think the new Factory Works / JC Racing hybrid gearbox would be the right setup, but have to think about it a little more. For now it's at a stopping point.
- Frankentruck
I have a nice 6 gear that has needed a home for a while. This chassis feels like the right one for it.
I didn't realize the AYK Buffalo had laydown rear shocks like this. I think I need to update the name to the Buff CAT
- Frankentruck
Got my bearings, in both axle sizes.
I don't use the jelly bean wheels very often, but since I have a nice set and the tires from my CC kit the 1/4 axles will get used in this build.
- Frankentruck
Now just the need to decide on a body.
https://youtu.be/7QIo3qcXDbQ?feature=shared
I think this Penguin body is going to be the right choice since it's meant to end in front of the rear shock tower.
- MarkyDents
- Has thanked: 1361 times
- Been thanked: 511 times
I like the low slung sawed off look of that body, great candidate for this build……
I’d say to figure out a paint scheme that shows off the lay down front shocks maybe either clear or trans candy. It would be a shame to cover them up.
Hey Cru ! Go balls out
- Frankentruck
We are thinking similarly on the paint scheme.MarkyDents wrote: ↑Sat Apr 06, 2024 5:58 pm I like the low slung sawed off look of that body, great candidate for this build……
Body is trimmed and fitted. Rear body mount was moved forward a little over an inch and a new gearbox brace was added.
- Frankentruck
Re: RC Top Faux Buff CAT 10
Started making some progress on finishing the bodywork. The painting went ok. Now more sticker work to do, and then picking out or making a rear wing.
A little peek through the suspension window...
https://youtube.com/shorts/ekFTM7OtfDs?feature=shared
- Frankentruck
Now I just need to work out the wing and electronics.
- RogueIV
- Has thanked: 1119 times
- Been thanked: 459 times
Lookin' good.
You could probably make a wing mount that integrates into the Transmission brace.
- Frankentruck
I hadn't considered using the brace. I was going to do the standard wing tube setup, I just hadn't put tubes in yet.
It looks like a wing will need to use standard length wire to maintain a little clearance to the rear wheels. This loaner wing has the RC10CC wire.
- Frankentruck
Wing is done. It needed a painted wing. Clear was just too invisible.
A little more sticker-a-facation. It needed tuning for a few more mph top end speed.
- Dangeruss
- Has thanked: 148 times
- Been thanked: 553 times
Very cool build. The front shock window and the billboards cut to fit the side vents are neat touches.
...then of course there's the awesome suspension.
- 29 Replies
- 5003 Views
Last post by askbob
- 1220 Views
Last post by QuackingPlums
- 20 Replies
- 1042 Views
Last post by jonboy
- 1089 Views
Last post by mogul
- 32 Replies
- 3142 Views
Last post by RCveteran
- 22 Replies
- 1434 Views
Last post by Retro rc
- 2230 Views
Last post by DerbyDan
- 1159 Views
Last post by Danf1275
Users browsing this forum: No registered users and 46 guests
