Friend gave me two B3s!!!
Re: Friend gave me two B3s!!!
A tightened diff did the trick, for awhile it seems. Idk I just tighten it almost to lock it? Longevity is definitely something I’m looking for.
https://imgur.com/gallery/NVAgOrF
Melted plastic taught me do not over tighten the slipper
- R6cowboy
- Has thanked: 518 times
- Been thanked: 554 times
I've found these vids to be helpful with ball diffs and slippers.
https://www.rctech.net/forum/electric-off-road/512013-how-properly-build-break-ball-differential-slipper-clutch.html
-Jerry-
Thanks for the info Cowboy!
New problem the metal turnbuckle snapped after a spin out. Worst part is that it snapped right at the ball cup socket. A lot of the metal seems to have aged poorly. Titanium it is! I can find kits and parts for the turnbuckle but can anyone point me to the cup socket that’s available? The original part is asc7230
I think after this I should be good. I know what to replace. Except shocks… those damn v2 .89 and 1.32 are impossible to find
- juicedcoupe
- Has thanked: 231 times
- Been thanked: 1747 times
Custom Works long cups are nearly identical. Even though they are discounted, I still run across the 7230's often.
RPM cups can be used in most places but they are a little bulkier than AE or CW cups.
AE turnbuckles and known for breaking and bending at the threads. I prefer Schumacher turnbuckles.
- juicedcoupe
Thanks a ton. I’d rather add the $3 to the cart then get this thing out
Wohoo! More parts! Could only find this damn thing from a seller in Korea. Thank you eBay.
First initial install with one red o ring resulted in the CVD barely making contact. Only one bone was making contact with the out drive. Even I know that probably isn’t good. Took it apart and added 2 more just to be safe.
Weighed them out to get a good starting part for the shock oil. After that used the old technique of pushing it in and seeing if they both push out at the same rate. This still good method? Also maybe any tips on droop? I may need to add little more oil
Installed!
Suspension unloaded
Load sitting?
Load settled
The first is me lifting it so the arms hang. The second is it placed after lifting it. The third is after I push the suspension down. Sorry if this examination is confusing. I’m using 30 weight in the rear.
These things definitely needed TLC. One was completely empty and the other was filled half way with black oil
Installed!
Suspension unloaded
Load sitting?
Load settled
I made it to the track twice! The first time oh boy, what a fun disaster. Ended up only breaking a rear shock mount. Surprisingly durable. All titanium turnbuckles, carbon fiber towers and the v2 shocks.
The second time I was able to clear the jumps better after adjusting the speed controller. Soft was nice for learning but wasn't zippy enough to make the 2 large jumps. Definitely got my steps going up and down to flip my car over. Damn was it fun though! After a couple of hours I was able to complete a lap! Haha the fast guys were under 20 seconds and I think I was lucky to get 30 seconds. New spur and lowering the ride height should be good for whenever I can make it back
https://i.imgur.com/Wwayh3K.mp4
- 1425 Views
Last post by besty22
- 282 Views
Last post by Lavigna
- 502 Views
Last post by vintage AE
- 21 Replies
- 2846 Views
Last post by shodog
- 3106 Views
Last post by XLR8
- 1209 Views
Last post by noony
- 635 Views
Last post by CavScout58D
- 367 Views
Last post by Halgar
Users browsing this forum: Amazon [Bot], Google Adsense [Bot] and 33 guests
