- Original Masami Hirosaka RC-10 GX prototype -
- Been thanked: 4 times
Re: - News from Japan... -
Well, I'll be the black sheep and say that no harm could come of doing a full tear down and rebuild*, 'cause can you collect vintage dirt? Great score whatever you decide, and a noble addition to your collection.
*while not changing a darn thing, that rear wheel cover may be tricky.
- RC10th
- Has thanked: 40 times
- Been thanked: 1015 times
There's no way it was 3,000 Yen. Thats only about $26 bucks.
- SHY
- Has thanked: 7 times
- Been thanked: 5 times
Oh wow! Leave it as is! Only touch it with gloves on!
Svein Harald Ytternes AKA SHY
The Nordic Vintage Challenge: http://www.ymr.no/nvc
Visit my showroom: http://tamiyaclub.com/showroom.asp?id=22039
I would clean it up and get rid of the rust but add all four wheel dots when done. Its one in a million and bet your well happy. I only got yokomo yz10 proto parts handed to me when I beat him at one of the rounds in the worlds warm ups but never in a million years would have believed you could buy one of his cars.
Designer of the Lazer ZX / ZXR Tub Chassis (now available again from Fibre-Lyte)
Sponser links below
http://www.fibre-lyte.co.uk/
http://www.kamtec.co.uk/
Sponser links below
- Asso_man!
- Been thanked: 70 times
Thanks for the compliments guys, I'm really stocked and still can't believe it is now mine. I'm still torn apart about what to do in terms of cleaning / restoring.
I am inclined to indeed drain the shocks and add early spring cups (non slotted) to the front shocks. I might also clean and remove rust from all metal parts (screws, bearings, alloy parts, CVD's, etc.) to better preserve it. I would not change a nut though or add anything.
After closer inspection, I can assess the car had a rear motor guard of some sort as indicated by markings and wearing on the chassis tail. Going by some pictures I could find of a similar car (the one with front lay-down Delta shocks, see below) and given the asymmetric two countersunk holes made in the tail, the motor guard was most probably made with a cut portion of a gold tub chassis. It could well be it had a (Yokomo?) undertray at some point as well.
I also opened up the 6-gear transmission to have a closer look at the internals and mods. Funnily enough, Masami used a LOSI spur ; the diff is pinned to prevent slippage; counter gears run on oilite bushings; and interestingly the internal support plate is an early (Edinger) one with the big C-clip. The motor plate has been cut diagonally to avoid bending it in a crash and a small portion was also removed below the two rear mounting holes. It looks like a dab of lube used to be in there. Also note the sealing stuff on the motor plate.
Also interesting is the way the rear wheel dots have been thought of: a small portion was first cut to allow easy access to the wheel adapter mounting screws and the wheel nut, then a second layer was applied to cover the whole with a small portion protruding on the tire to be able to peel it off easily. the two missing dots are a bit of a mystery to me.
Close-up of the Hot Laps rear plastic adapters, note the use of clamping washers on the 2 wheel screws:
Close-up of the custom rear shock tower and flipped over rear bulkhead:
There are "RACE" writings on each front tire and a pink number "2" can be seen on the front bumper, probably to easily differentiate this chassis from another similar one?
Come and visit the stable
- Asso_man!
And for the sake of documentation, I've compiled below a series of pictures of RC10-GX (the Japanese name for "Graphite") cars from the same era:
- slotcarrod
- Been thanked: 41 times
Re: - Original Masami Hirosaka RC-10 GX prototype -
As usual for you, top notch!
Surprised his gear box was so dirty!
Rod Littau
- Asso_man!
I was more surprised to find an early centre plate with c-clip and bushingsslotcarrod wrote:As usual for you, top notch!
Beautiful. I wouldn't touch a thing on it , not even the dirt/dust. I am in awe. Then again, I'm a little obsessive. If I could , I'd hermatically seal all my vintage cars.
- slotcarrod
Wow bushings!
Rod Littau
- skunk.werkz
Remember its only original once, I doubt any of us will get to own something like that in our lives. You're the caretaker now...
- 5143 Views
Last post by DemZ
- 1544 Views
Last post by limestang
- 527 Views
Last post by BattleTrak
- 2272 Views
- 1088 Views
Last post by superfly
- 708 Views
Last post by fredswain
- 1255 Views
Last post by Ronbo
- 301 Views
Last post by Mr. ED
Users browsing this forum: No registered users and 43 guests
