New to me Cougar 2 Works
Re: New to me Cougar 2 Works
Yeah, those brass bushings are a pain. Those are the correct bushings. Try some penetrating oil and some vice grips wrapped in tape as to not damage the bushings.
Good luck!
Good luck!
- Momo5
I cant believe its been 4 years since I bought this, and I've done a little here and there but still have a ways to go. What do I need to rebuild these shocks?
Time... . Use Losi shock cartages. They will require a few spacers to make the shocks the same length as stock, but well worth the trouble. -Jeff
- DerbyDan
- Been thanked: 17 times
Wow - thats a great 'top-tip' - I didn't realise that the threads between the Losi & Schumacher bodies matched up?Jay Dub wrote:Time... . Use Losi shock cartages. They will require a few spacers to make the shocks the same length as stock, but well worth the trouble. -Jeff
@ Momo5 - sure looks like those shocks have dumped their oil all over the front end of your Cougar
It's hard to tell from the pics, but are those shocks the correct ones for a works? They look like the silver ones from the Team car, where the Works should have the dark green shocks.
Paul.
Paul.
Well, they don't really. However the diameter works, and the threads are close enough. The cartrages (plastic ones) will cross thread right in. I used them on all my cars for years. The factory didn't like it -but along with easier maintenance, also offered more droop range. -Jeff
- Bormac
- Has thanked: 21 times
I never had much luck with those plastic shock seal housings to be honest. They always seem to leak no matter how well I build them.
I am running the purple alloy shock seal housings. They work extremely well!
- 2997 Views
Last post by DerbyDan
- 2727 Views
Last post by yorak
- 1310 Views
Last post by hkp
- 1068 Views
Last post by isobarik
- 30 Replies
- 4776 Views
Last post by Momo5
- 1718 Views
Last post by 8rad
- 1816 Views
Last post by Lavigna
- 1398 Views
Last post by moozo
