The Vintage 1/8 Onroad Thread
- Has thanked: 13 times
- Been thanked: 78 times
Re: The Vintage 1/8 Onroad Thread
Romulus 22
Could you please contact me through Classic RC museum regarding your Dash.
https://classicrc.wordpress.com/about/contact/
Send you message also through ....
PM here doesn´t work at me
Thanks
Thanks
- romulus22
- Has thanked: 664 times
- Been thanked: 662 times
Message sentV12 wrote: ↑Tue Jun 11, 2019 7:06 pm Romulus 22
Thanks
- FASTEDDIE
- Regular Member
My MARKER CARS Chassis Pan car.
And Associated and RC250 club car.
I've personally owned the Marker since about 1972.
Bought it at Trost Hobby Shop in Chicago.
Bought it to Race the circuits but didn't work out as planned. Just raced some local area races.
Some years later I bought my Associated car. The Marker is just a rolling chassis now, stripped it down to a basic chassis. cause I was going to update it from scratch. Then the sport locally started to fizzle out. So started racing real cars instead and my poor Marker just sat in the closet for decades. Has a Steed Lola body which I started to strip to repaint and never finished.
My Associated car is about 95% complete running chassis. Didn't finish this one. Car engine OS MAX 21 Is brand new never fired.
Chassis never run. Approx. 50 years I've owned my Marker.
- Attachments
- Has thanked: 31 times
- Been thanked: 39 times
Very nice car. Too bad 1/8 bodies aren't like that anymore, that looks wicked.
- KidAgain
- Has thanked: 288 times
- Been thanked: 198 times
Anyone ever done an electric conversion on one of these 1/8 scale cars?
Gone: RC10, Jrx-2 and Jrx-t
Current: 3 SC10 first gens, 3 SC10 Street Outlaw's, 12 RC10 DS’s, Carbon RC10T, RC10LSS,RC10L, RC10 Graphite,RC10 B44
Yes. Just finished my Delta Super-J electric runner https://www.rc10talk.com/viewtopic.php?f=33&t=46770
- Incredible_Serious
- Has thanked: 1405 times
- Been thanked: 861 times
And just like that, without me trying, I've managed to build a collection (pile?) of vintage 1/8 onroad stuff.....
- A lexan driver figure, that came with a bunch of Associated stuff...
- Two packs of AJ's (by Twinn-K) racing slick rear foams, with Goodyear printing
- Three pairs of mounted Serpent rear wheels and foams, identified as possibly Mk3 or early Quattro, but I'm not 100% (no hex inside fitment)
Awesome things to have sitting around.... now to work out what to do with them!!!
- Couple of bodies, a Matich SR4 and a Mongoose Indy 500- A lexan driver figure, that came with a bunch of Associated stuff...
The Serpent rear wheels are MK3 and early Quattro indeed.
The hex inside was introduced later when they made their first quick release system.
I personally had a MK3 and an early Quattro back in the days. I started with an used MK3 Super Pro and changed to a Quattro one year later.
In the beginning I used exactly those wheels but also bought the quick release wheels and hubs when they were available.
The early Serpent wheels use exactly the same hole pattern for mounting to the hub as found at a certain other brand named Th...
Actually they used those wheels for their first car and kept the system when they designed their own wheels.
- Phin
- Has thanked: 61 times
- Been thanked: 182 times
Can confirm...this can happen.Incredible_Serious wrote: ↑Tue Oct 26, 2021 6:45 am And just like that, without me trying, I've managed to build a collection (pile?) of vintage 1/8 onroad stuff.....
Picked up this RC500 along with a Delta Eagle (still needs cleaning) a few weeks ago. I'm very much a noob when it comes to 8th scale stuff, but it seems to me there's a lot of interesting custom work on this car. I believe the car might have started off as an early RC500, with the criss-crossed rear shocks as the upper rear arms have had the shock mount point shaved off. The car came with some spare early RC500 parts as well. It has been upgraded with the light weight ball diff, and spur gear hub though. It's also got a few Delta parts on it...tank, bumper, and wheels.
The chassis looks flimsy but both upper and lower chassis plates are 5mm thick so it's very stiff...and while the hand filed cut-outs make the car look like a bit of a hack job the chassis was likely originally machine cut. I also believe the chassis is longer than stock and it's got a custom aluminum motor plate that is shorter than stock to compensate. The wheelbase as it's built comes out to 305mm but the lot also came with a couple of longer motor plates that can stretch the wheelbase to ~316mm.
The shorter motor plate has the name Grasby scratched into it, which I assume is the name of the original owner/builder.
Nice find.
It seems to me the car have been built to do some sort of rally cross style racing.
The RC500 came with a ball diff. It´s quite possible the diff was replaced with a solid rear axle later, after racing went to 4WD.
The tank was made by Delta indeed but also sold to Associated for the RC500. This was also confirmed by Gene Hustings at one of his videos.
I think this is also for the bumper.
I can´t check the wheelbase of my own RC500 as the car is deep in storage.
Maybe I´m wrong but even the wheelbase of 305 mm is quite long. This is usually found at the old pan cars where suspension cars usually use shorter wheelbase of around 295 mm.
Yes the extra pod plate is the stock version. Seems the chassis was stretched a lot but I have no idea what sould be the purpose.
- Phin
I think you misunderstood...it has a ball diff not a solid axle. It is the reduced weight ball diff though which I think came later than the suspension arms.
That's good info I didn't know about Associated using the Delta tanks. Thanks. The lower chassis is specifically cut around the Delta tank's shape so that it's as low as possible. The bumper came off the Delta Eagle I bought with the RC500. It's scratched up and I have one in better condition to use on the Eagle.The tank was made by Delta indeed but also sold to Associated for the RC500. This was also confirmed by Gene Hustings at one of his videos.
Yeah I believe 295mm should be the stock wheelbase too. The longer motor pod plate is also custom modified for this chassis. It has two extra screw holes for connecting the two aluminum upper braces...they'd be too short to reach the upper chassis otherwise.I can´t check the wheelbase of my own RC500 as the car is deep in storage.
My guess is the longer wheelbase was better for the track this car was raced at. Maybe it was raced on an oval track with a NASCAR body. It's funny you mentioned rally cross though, because I did think that a Kyosho Circuit 20 Datsun 240Z body would probably fit the car.
Yes misunderstandings ...
I mean the RC500 came with a diff right in the kit. And the diff maybe was replaced later by a solid raer axle. Not at your car but for the RC500 in general, at least for the 4WD versions.
I don´t know about two versions for the ball diff but yes it´s possible.
- Phin
Again I'm a noob when it comes to 8th scale stuff...my info on a light weight diff from Associated comes from this 1984 article from Model Builder magazine:
After a re-look though the diff in my RC500 isn't exactly like the one in the article, so I'm thinking now the weight reduction might have been more of Grasby's custom machine work.
- MadZero
- Has thanked: 33 times
- Been thanked: 15 times
This must be what heaven looks like
old glow engines make me happy
- romulus22
This was an “if you find it, you buy it” scenario for me. Starting to question if I’ll ever build it, still collecting stuff to fully build it if I do.
- 582 Views
Last post by V12
- 2329 Views
Last post by V12
- 34 Replies
- 5275 Views
Last post by magic
- 35 Replies
- 6025 Views
Last post by xo1tech
- 1477 Views
Last post by a01butal
- 462 Views
Last post by Lowgear
- 431 Replies
- 39485 Views
Last post by Eccentric
- 1471 Views
Last post by Basher67
