McMaster Carr goodies
- littleVETTE
- Has thanked: 6 times
- Been thanked: 9 times
Re: McMaster Carr goodies
1mm x 10mm are the ones. they fit perfectly fine, and haven't had any problems or leaks.
this is the part number i used:
http://www.mcmaster.com/#9262k104/=u00vqj
- Has thanked: 822 times
- Been thanked: 2418 times
Ok yeah those are different- jwscab said 12mm and 85edinger ran with it, the number he posted are larger and that's what I ordered. I'll get it right next time.
Factory Works website
- littleVETTE
i would of gotten the silicone o-rings, but those things are 9 bucks a bag for 50 of them. so for under 6 dollars, and for 100 o-rings you can't go wrong. it's not like we're racing these things in a freezer or on the sun.
I think the Buna are fine for the cap, but I tried them on the shock shafts and didn't like em. Wish I could figure out where MIP got his blue ones. I liked them!
- LTO_Dave
- Has thanked: 46 times
- Been thanked: 225 times
Same here. I have a few bags of NIP ones that I found on the web a few years ago that I'm saving for some HG VLT bodies.gomachv wrote:Wish I could figure out where MIP got his blue ones. I liked them!
- littleVETTE
yeah for the o-rings i would stick with the silicone stuff. and with a dab of green slime the shafts will keep sliding lovely.
those mip blue seals were pretty popular. people still ask for them today. for me they were ok. but when i tried them, every once in a while, i would get one that would swell up and cause havoc with the shock. would piss me off, because i had to rebuild the damn thing all over again. and if you bought only one pack of mip seals.... so i just stop using them and stuck with the stock o-rings.
- littleVETTE
another tip for you guys if you didn't know already. instead of buying those little tubes of team associated green slime just buy a little tub of this stuff. it's same stuff as the green slime. noleen sf-3. and all you need is one. it'll last you for quite some time.
http://shop.noleenj6.com/product.sc?productId=8
and stock up on those o-rings too while you're at it...
I can't make out the orange oring sizes, I know the -104 but what else are you stocked up on there?
- littleVETTE
1/8 id x 1/4 od, 1/16 diameter o-rings. the rest of them are for the modern yokomo big bores.
- Has thanked: 10 times
- Been thanked: 447 times
Yeah that was my bad. The 10mm rings would prob work much better.
There are o ring suppliers you can probably get in touch with to get the silicone o rings in bulk. Team durango sells blue silicone ones, 8 to a pack so not very cost effictive.
- 956 Views
Last post by Halgar
- 1164 Views
Last post by juicedcoupe
- 900 Views
Last post by rctenracer
- 14840 Views
Last post by Cpt.America
- 1243 Views
Last post by kaiser
- 792 Views
Last post by MarkyDents
- 47 Replies
- 6987 Views
Last post by LosiXXkid
- 47 Replies
- 6842 Views
Last post by License2iLL
