toolman72 wrote: ↑Mon Oct 25, 2021 1:25 pm
Great find. I have been around nitro rc and control line planes for many years. The engine seize issue is a very easy fix.
1 remove exhaust,glow plug, carb and clutch. Soak entire engine in Marvel mystery oil its cheaper than nitro fuel and works great, if you want add a little wd-40.
2 I have a zip lock bag full of gt tanks,send me a pic and I could help you out there and probably any other issues that arise.
I dont have a pull start for that engine,but a bump box would be your best bet and a great investment.
Yes, could you please help? Pm me and we can work out the details.
So, still looking for an option on the fuel tank. Do any of you guys have a solution on mounting an aftermarket tank? I can get the engine rebuilt/cleaned even get a traxxas one. But the fuel tank is kind of flummoxing me. Ideas, improvisions?
So, put in new shock towers, add the metal diff gear and get the engine free. Put it back together and give it a new body. Would like to get some titanium turnbuckles.
Would “super clean” degreaser do the same? And should I put the engine in a appropriate sized jar and submerse it in mystery oil? Got some today and basically got the engine tipped so it holds some in the exhaust port where the piston is locked. Please advise. Plan on seeing if I can get it to move tomorrow.
Got the engine free and turning. She is now soaking in a mason jar and will let it sit. I’m hoping the marvel oil will help remove the varnish. Just glad it is turning rather nicely. After a good soak I will pull it all apart and clean.
Engine is all cleaned up and has really good compression.
Next up is to rebuild shocks an add the carbon towers. Also picked up some blue factory team turnbuckles. Only other question I have is regarding fuel tubing. Is it sized based on outside diameter?
Started rebuilding the rear end. Ran into a snag, found that the previous owner stripped out the left side suspension/ rear arm mount. Guess that’s what the nut and bolt was for in previous pic. Kind of suspected that. Using up some left over blue hardware from my xxt build.
I recently began to look for vintage RC10s and RC10GTs. Here is my last addition to my collection.
A brand new, never ran, RC10GT black tub chassis.
Ok, here is what I know-
The Prolines on it are Pro 95 / Pro 90 used from 95 (T2) until 97 (T3) at which point Proline abandoned the pro label and starting calling the tires by name ie- the pro 95 became just the edge and the pro 90 was...
Im bring my old gt back to life that I got in 89
My slipper slip's even with it very tight ,I can't remember do you glue one side of the pad down
Thank for your help
Got the THS pipe mounted , raised a little hell with my pull strat but it will work onto I can get a rotor start plate
First off I must give Todd (romulus22) a huge thanks for giving me the opportunity to own such an amazing RC10GT.
This truck doesn't need anything to look pretty on the shelf. I wanted to freshen it up and give it that like new appearance, tidying...
Those are awesome. My blue chassis GT truck is that clean. I'm getting the body for mine painted really soon. I just have to get a few more details to get ironed out for it. Will post pics when done.
Hello all! Another RC10GT addict to join your ranks! Figured it’d be fun to discuss the best nitro stadium truck ever built among fellow enthusiasts, so I signed up.
I’m currently running three GTs, a Blue FT chassis, a blue RTR chassis and a black...
I think the altitude does have just as much effect on model engines as it does on large engines. I also fly rc airplanes, and you have to tune them slightly rich on the ground because they lean out in the air. And that's only a 200-400 foot...
