Behind the curve RPM
- MarkyDents
- Has thanked: 1361 times
- Been thanked: 511 times
Re: Behind the curve RPM
Looks fantastic, I thought I remembered that the FW CC chassis set didn’t have the complete lower chassis with front kick up. That you would need to have a 10T noseplate …..
Hey Cru ! Go balls out
- Has thanked: 822 times
- Been thanked: 2418 times
We made two versions- the “cheater” chassis are flat g10 chassis plates that use a bolt on stock nose. The other version was a one piece aluminum chassis that was black anodized, which is what you see in this build. We did a small batch to check popularity and it wasn’t nearly as expected. Took a while to sell the first 10. Adding to that they were not the easiest to manufacture since we had to outsource the cnc bending and anodizing. They may reappear one day but this was one of many lessons learned. If 10 people say they want one, you might get 2 that reply when they are ready and 1 will actually purchase it.MarkyDents wrote: ↑Sun May 15, 2022 11:40 am Looks fantastic, I thought I remembered that the FW CC chassis set didn’t have the complete lower chassis with front kick up. That you would need to have a 10T noseplate …..
Factory Works website
- MarkyDents
Understood, and somewhat unfortunate.
But I’m also hearing this is one of 10…Sweet
I’m thinking a good chassis protector is in order considering this to be a runner.
- 2552 Views
Last post by Winger
- 1116 Views
Last post by blown5.0
- 572 Views
Last post by Caine
- 361 Views
Last post by TViz
- 865 Views
Last post by slow_jun
- 447 Views
Last post by aconsola
- 1813 Views
Last post by carloco8
- 1707 Views
Last post by wyldbill
Users browsing this forum: Bing [Bot], DotNetDotCom.org [Bot], Facebook [Bot] and 43 guests
