GRAUPNER Rally Sport (touch the end) - Fairlady 240Z
- Has thanked: 2287 times
- Been thanked: 1994 times
Re: GRAUPNER Rally Sport (Datsun)
Good find and good you've found a project to finish , what are the radio boxes made of , I can't tell from the pictures if they are lexan or ABS , if they are AbS then you could use a 3d pen to weld up the cracks , you'd have to sand it down flat afterwards but it would make a strong repair .
- Has thanked: 263 times
- Been thanked: 155 times
Thanx,Dadio wrote: ↑Sat Apr 04, 2020 4:48 am Good find and good you've found a project to finish , what are the radio boxes made of , I can't tell from the pictures if they are lexan or ABS , if they are AbS then you could use a 3d pen to weld up the cracks , you'd have to sand it down flat afterwards but it would make a strong repair .
it's like ABS, but i'm not sure.
This is the next step
Sanding, primer, sanding, paint...
new screws :
for next days to come
for the seconde radio box, i will maybe only use varnish
Jerome
Looks really good , i love the front suspension its so scale real .
Re: GRAUPNER Rally Sport (the end is near) - Fairlady 240Z
hi everyone,
I pretty much advanced on what I wanted to do even if I made a big dumpling ...
So, I repainted the rims and it was the easiest, I continued the radio installation and rebuild the mecha esc, I drilled the radio box for the antenna wire , I "pimped" the vintage radio, I took pictures to shit as usual ...
I start by showing you the dumpling, namely a cutout for the passage of the motor cables in the cover of the radio box freshly repaired and repainted ... BIG DUMPLING because I made it 5mm next ... suddenly I l have left (I am an asshole).
In short, luck is that I redid two covers of radio boxes, the second will go on the chassis.
Otherwise, I therefore have "PIMPED" the radio with A2 stainless steel
After, so I repaint the rims
Then, the radio part (I haven't finished inside) and some wiring
And, I still tried to make a little prettier pictures
More in the coming weeks (or days);)
Jerome
Jerome
Re: GRAUPNER Rally Sport (touch the end) - Fairlady 240Z
Here we are, the end of the tunnel.
Script on tires
Inside the radio box
Jerome
Script on tires
Jerome
looks fantastic , quite jealous really
- RC10resto
- Has thanked: 1110 times
- Been thanked: 430 times
Very nice
I would be tempted to spray the hood / bonnet flat black.
Cool car.
Cool car.
Thank you.
Hope you to find one and restore it
Thank you,
Maybe with a ropro body when i'll buy it
Jerome
- 784 Views
Last post by Mr. ED
- 3193 Views
Last post by Diamond Dave
- 38 Replies
- 8758 Views
Last post by Mr. ED
- 2016 Views
Last post by Oldtimer13
- 1927 Views
Last post by magic
- 106 Views
Last post by hugger19
- 399 Views
Last post by Jerzi
- 1010 Views
Last post by TomEG
Users browsing this forum: Google Adsense [Bot], Mr. ED and 9 guests
