Thanks Corsa took me a while to get all the Carbon bits together but just about done, will give it a run this weekend along side my Worlds re re looking forward to getting it on track
So I started a while ago on this car and never finished it.
The chassis doesn't line up well with most bodies and it got sidelined for a while.
Anyways...
The chassis had been cut/carved where the front arms were touching the chassis on full...
I watch Andy's eBay listings but only see the painted bodies getting listed. I wasn't sure if there was a different retail source with a set price. Wishful thinking.
He had some clear Pro Arrow and Renegade bodies listed a while back.
It has been some years since I have posted. I sold most of my cars and custom builds some years ago.....of course I regret selling some of it. Only stuff I have left is in my signature.
I joined Facebook only because it seems like many people moved...
I added a note to the first page.
I switched to CW rear hubs and B44 CVD's.
The bones were too long at 67mm.
I will get to the electronics on this soon.
I'm super curious - how does the graphite tub chassis perform on the track? Have you or...
This project started when I received a darn nice graphite chassis except for the fact that the front of the chassis had been cut on the ends of the nose. So much that only half of the outer holes for the a-arm mounts were there :evil: So i dug into...
Very nice, ballsy to run those arms though-
I do have a set of the dynotech arms, I may change them. The arms are actually not as nice as they appear in the pictures. Someone took a dremel to the shock area for clearance :evil:
My usual pusher, oh oops I mean friend who frequents the local flea markets and craigslist ads brought a nice haul to work the other day.
He is not an RC guy, so I offered as usual to clean up / rebuild (and thoroughly inspect of course) the...
Well i bit the bullet this morning my chassis had a flakig spot on the kickup small but bitherd me non the less i was gona super glue it and clamp it and make a bumper for is so it wouldnt get worse and i lost my clamp so this morn i got out an old...
well Durafix and aluminum rod were a huge epic failure. stuff just didnt flow and didnt stick well.. i tryed a aluminum braze rod with flux also and that was a failure too, i knew when the welding supply place said i needed a oxy-acetylene torch to...
I'm considering fitting hard coated shocks to my RC10 graphite build - the ones which have grey bodies but what looks like black anodized shock caps. Do you guys usually use this kit for these purposes? , or are there others which are more truly...
The correct ones are like these, the darker grey shocks were old stock--they got lighter anno
as time went on, you would need the .71 kit for the front, and the 1.32 for the rear with black
alum caps to be just right, and try to find the white...
