RC10GT Refresh
- RC10th
- Has thanked: 40 times
- Been thanked: 1015 times
Re: RC10GT Refresh
I'm finally starting to make a bit of headway with this build. Most everything is cleaned and prepped for assembly. I decided against peroxiding everything and will only peroxide a few things like shock collars, retainers and a few other misc bits.
I need to pick up some pipe cleaners tomorrow to clean threads/holes in the nylon. Hopefully I'll have an update tomorrow when I actually start to put something together.
- RC10th
Re: RC10GT Refresh
Woo hoo, time to start assembling this truck.....
It will kill me to open and use this 7200 Front Suspension Kit as I've had it for probably 6 -7 years, it is perfect!! I bought it to use one day for a GT and this may be the one day. I've also got a NIP front bulkhead and body mount brace to go with it.
- littleVETTE
- Has thanked: 6 times
- Been thanked: 9 times
- RC10th
Re: RC10GT Refresh
that's too funnylittleVETTE wrote:open that thing like a bag of chips!
Marlo, I missed out on a matching rear suspension kit on ebay a few months ago. I was watching it but forgot and missed it
- RC10th
Re: RC10GT Refresh
I don't "need" to use it but....
It has thicker front arms but hex axles which is odd isn't it?
- marlo
- Has thanked: 21 times
- Been thanked: 21 times
Re: RC10GT Refresh
Should be aluminum in-line axles with the thick arms. Do you have carriers in that kit, if so they should be 30* (#6210), or a least when the in-lines are used.RC10th wrote:I don't "need" to use it but....
- littleVETTE
Re: RC10GT Refresh
these kits i believe came with the standard 15* carriers. the 30* carriers didn't quite come out yet.
- RC10th
Re: RC10GT Refresh
Well, the 7200 got murdered.
This is a fun build so far, it takes me back to when kits came white. Not everything will be NIP but it should look good when done.
- RC10th
- RC10th
Re: RC10GT Refresh
Finished the transmission which came out pretty good. Good enough for me at least. I bought a new brake bracket and shoe but the original stampings were squarer, I'm trying to keep this as close to original as possible.
- RC10th
Re: RC10GT Refresh
Last bit done for tonight, engine mounts, trans, rear bulkhead, brace and tower installed.
It's coming along nicely...
- marlo
Re: RC10GT Refresh
If those arms are the Thick one hole type that's correct. I had assumed it was a two holed arm.... which I believe to be correct for this build.littleVETTE wrote:these kits i believe came with the standard 15* carriers. the 30* carriers didn't quite come out yet.
- RC10th
Re: RC10GT Refresh
I believe this truck was all original, the castor blocks were the same as in the 7200 kit. This 7200 had thick one hole, inline hex. The front shock tower had two ball stud locations and three shock mounting points.
The manual also makes mention of single ball stud two shock position towers.
- 1105 Views
Last post by hugger19
- 1650 Views
Last post by LTO_Dave
- 524 Views
Last post by rfulcher
- 20 Replies
- 4077 Views
- 1089 Views
Last post by Bottom Feeder
- 27 Replies
- 1696 Views
Last post by mikea96
- 965 Views
Last post by matt1ptkn
- 1095 Views
Users browsing this forum: No registered users and 15 guests
