Triumph Discussion
jkelm24
Has thanked: 20 times
Been thanked: 77 times
Re: Triumph Discussion
Post by jkelm24 »
I was able to replace the standard spur with a Durango one and slipper pads by putting a bearing in the centre of the spur. to get the slipper to lock down properly I had to put a 4mm washer up against the outer slipper plate to make up for the narrower spur gear
Can you clarify your spur/slipper setup? Did you also use the Durango slipper and pads, along with the Durango spur?
What size bearing was required?
Also, for the washer... was that a 4mm spacer, or 4mm OD washer?
If this is s successful setup, I'd be interested in doing the same on a future runner.
Delorean
Has thanked: 14 times
Been thanked: 14 times
Post by Delorean »
Hey mate. its a Durango 87T spur and Durango slipper pads. the 4mm is inner diameter, the shaft diameter is 4mm so you don't want the washer flopping around, the outer diameter is 11mm as you need the washer to be wide enough for the spring washers. The bearing is 4mm inner diameter and I think 8 or 9 mm outer (will confirm)
Delorean
Post by Delorean »
and the slipper plates are just the standard kyosho ones. the other benefit of a setup like this is you get more spur choices, by the looks of it, Schumacher spurs could work in a similar way. This sort of setup should work on a lazer too from what I can see.
HKS_TRD
Post by HKS_TRD »
Delorean wrote:
I know someone was talking about seeing if fibrelyte have done the triumph parts in CF. if they don't, im happy to send parts to them so they can take measurements
That may have been me on the Oople forum. I've since gotten my hands on a NIB Triumph but wouldn't mind building up a second all carbon runner, the chassis is easy to get at the moment but that may change down the track and front shock tower only ever seen one. I'm not sure till it lands if my NIB Triumph has the FRP or Kelron shock towers
j0pp3
Post by j0pp3 »
Also got a Triumph N.I.B (with FRP towers). Maybe it will be built one day :)
Cheers
Joel
HKS_TRD
Post by HKS_TRD »
Mine came in and it has the FRP towers too which was a Relief
I have a purple Kyosho battery pack just waiting for it
I'm already itching to build it!
RichieRich
Has thanked: 34 times
Been thanked: 19 times
Post by RichieRich »
Wait, so there were two different materials used for the shock towers? I'm pretty sure mine are FRP. Also, did some versions come with universals instead of dogbones?
j0pp3
Post by j0pp3 »
RichieRich wrote:Wait, so there were two different materials used for the shock towers? I'm pretty sure mine are FRP. Also, did some versions come with universals instead of dogbones?
There was indeed two different materials for the towers. Same art numbers I believe. Here's a pic I borrowed from Ebay showing the kelron plastic version. One can clearly see the rounded marks from the mold process.
Cheers
Joel
RichieRich
Yuck. I wonder if that was a running change. I definitely have the FRP towers.
sdrob
Post by sdrob »
ok firstly great thread, mainly because i just got my hands on a new partially built TRIUMPH.. the car has been sitting in a roof unfinished so the seller says.. i got the car and seems the story stated seems true.. the car had been started but so much was built wrong i dismantled it and started again.. after completing it the only things missing are the front wheels and tires and body.. the body i have found at TBG but the front wheels....that is a different story..
so can the original wheels be sourced anywhere??? or what other wheels will fit..?? i know there was another thread that said HPI wheels, but does anyone have part numbers??
the car seems very unique in the way it tackled rear toe and a gearless gearbox.( love the dual belt drive ) the car overall seems quite simple but effective... but seeing this is brand new i can't bring myself to drive it...so i'm thinking a driver might need to be found..lol
HKS_TRD
Post by HKS_TRD »
Just reading this thread again I was wondering if it would be possible to use the alternate slipper setup on a Lazer ZX-R MKII seeing as they ran the same spur and slipper pads as the Triumph
RichieRich
Two great questions. I think you can use RB5 rear wheels. For the front, you may have to use an imperial axle to get maybe B3 wheels? The problem is nothing modern is going to fit that 4mm front axle.
As for the slipper, what is the "alternate" setup?
HKS_TRD
Post by HKS_TRD »
RichieRich wrote:Two great questions. I think you can use RB5 rear wheels. For the front, you may have to use an imperial axle to get maybe B3 wheels? The problem is nothing modern is going to fit that 4mm front axle.
I just meant the Durango slipper setup
Delorean
Post by Delorean »
I haven't actually done it on the zxr I have no doubt the slipper setup would work the same
as for front wheels on the triumph, I used tamiya dt02 front rims and bought bearings with 4mm inner diameter for the axel and I think 10mm outer for the wheel
Rears I used team C / ansmann rims
EvolutionRevolution
Been thanked: 36 times
Post by EvolutionRevolution »
Is it possible to mount an Ultima transmission to a Triumph chassis?
Post Reply
  • Controller Discussion
    by mikedealer » » in Modern Electronics
    Last post by GJW
  • B5 and B5m discussion.....
    by Orange » » in Off-Topic / Chit-Chat
  • Trailing Arm Discussion
    by JK Racing » » in R/C Off-Topic / Chit-Chat
    Last post by bgruen
  • Discussion - shelfer or runner
    by scr8p » » in Off-Topic / Chit-Chat
    Last post by Tadracket
  • is there a place for rc8.2e discussion?
    by pcrussell50 » » in Off-Topic / Chit-Chat
  • dirt oval discussion
    by kaiser » » in Temple's RC10 Tech Forum
    Last post by askbob
  • Forum News & Discussion
    by Lowgear » » in Site Questions/Comments
    Last post by Lowgear
  • NIX91 Racer discussion thread.
    by Mark Westerfield » » in CNCrc
    Last post by Niki
Return to “Kyosho Forum”
Users browsing this forum: No User AvatarBing [Bot] and 16 guests
