Yes......the hard-to-find Losi A-1101 XX Bulkhead.....I watched both those auctions recently on eBay with surprise at the final selling price.Sascha3741 wrote:Looks like you've got the basis for a great car there.
Some parts are getting hard to find though, in particular the front bulkhead (LOSA1101) There have been two ebay auctions over the last few months for nip bulkheads, the first went for just over £50 and the second for £48. Even a secondhand one went for £24 recently! If you have a few spare ones then great but if not I would start looking for replacements now, as they are fragile. The later white versions are much better but equally elusive and the alloy versions are almost impossible to find. Also, if you do enough research you'll find posts online advising to look for the duratrax evader version. These are not direct replacements and require a lot of work to fit, you'll also need the shock tower as well which needs to be modified and the chassis brace won't fit either. You could use tie rods instead of the brace but by the time you've done all that you've effectively got the front end off a different car. Another option would be to buy another xx and use it for spares.
Anyway, don't be put off and good luck. Would be great to see some photos of it racing, the track you mentioned should be perfect for the xx.
Sascha
I might have to look at getting some CNC machined, as opposed to being injection molded, using an original as a template. I'm sure there's a company out there that can scan the original into CAD and then produce a small batch.
I would think that there is enough demand considering the recent eBay 'prices'. A bit of research is required me thinks.....
