i Get snake feet and visceral
- Mr. ED
- Has thanked: 58 times
- Been thanked: 56 times
Re: i Get snake feet and visceral
they both had these cheap connectors from the box.
But I think Kysoho usually had yellow copper ones, and the wire colors were white and red.
Tamiya had yellow and green wires with the grey connectors pictured.
Eitherway: both are guaranteed to give you heating rubber insulation after a while and are a disgrace on this beatiful creature
- Been thanked: 288 times
True, a better option is to replace the connectors with gold-plated 3.5mm bullets, especially if you're planning to run a modern battery & ESC. Those tiny-gauge stock Mabuchi 540 wires (yellow & green) and Tamiya bullets won't stand up. What I actually did was upgrade the connectors on my cars to 3.5mm bullets and removed the clear silicone boots from the Tamiya connectors and used them with the new gold bullets. Best of both worlds!
- Mr. ED
Looking good.
I must admit I'm not so familiar with the original car. Are you building this as designed? Or is it your own design?
It looks like you'll need a very compact steering setup: like the sliders from Kustom Works.
thank you
ayk tire is rare and expensive i think use tamiya or Other new tire
is it my own design I still slowly conceived
I think to find the right his body
I AM CARL LIN
Hi, Saga101, great build!
Could you tell me the diameter of the sprocket there, that comes out of the gearbox and drives the front gearbox via chain? also how many teeth are there?
I am working on a kyosho Datsun project where I am working on a custom gearbox borrowed from the assault, just want to know if this sprocket will fit before I buy it on ebay! The seller is not responding
thanks!
thanks!
- 21 Replies
- 2378 Views
Last post by RC10resto
- 1271 Views
Last post by Burniefloyd
- 455 Views
Last post by GreenHell
- 1310 Views
Last post by tamiyadan
- 427 Views
Last post by Halgar
