Hi aaron, so yours is milled at the rear? seems odd for a company to go through the anodizing process then mill it?
Must say it does give a flash custom look!
Identity Please learned Folks!
- Has thanked: 135 times
- Been thanked: 23 times
Re: Identity Please learned Folks!
Yep it was milled just as yours. I sold mine about a year ago to a fellow enthusiast in France I believe. I held out hopes of finding the front, but that just was not going to happen. I had better luck finding the stock Aluminum units from Yokomo, and went that direction Yours is the only other I have ever seen.
The rear hubs are a tad different in design. The fronts, well the blue are stamped and dark like yokomo back then? But the blue differs from
the rear hub blue(could be just a run variance). Both reds match, the front not being stamped. Anyhow Ill stop there....I aint much idea!
Oh and did the yr4 ever come with the old bush system for the steering kingpin/bolt?
steve
steve
- 832 Views
- 810 Views
Last post by Toaster
- 134 Views
Last post by gtv1
- 727 Views
Last post by DMAT
- 85 Views
- 2135 Views
Last post by shodog
- 1178 Views
Last post by WhoKnowsWho
- 1715 Views
Last post by mamadoesntletme
Users browsing this forum: Bing [Bot] and 12 guests
