Looking forward to seeing how long it goes...tesla33 wrote:Anyway I ordered new axles and hubs (t bone this time) and will install a 10.5 engine and voila that should do the trick! Will let you know!
brushless on brat
- Been thanked: 288 times
Re: brushless on brat
- Lonestar
- Has thanked: 626 times
- Been thanked: 166 times
... and that poor little chassis altogether that barely handles at all with the stock 380kaiser wrote:good luck, thats still alot of power for that poor little gearbox.
Fixed it! Changed the transmission kit to wishbones and now it flies!!!!! 1 hour of bashing with a 10.5 brushless and still seems to be going well! Hope it lasts.......
The hex axles wear out fairly quickly, I believe - not the greatest of designs. I remember on my Fox that they used to go very regularly (even with the standard 540 motor) which is why I upgraded to the dogbone set-up - much longer lasting....tesla33 wrote:Ok, took the brat apart and its wasn't the gears or diff in the end! They were fine! It was the axles that wore out and were turning freely in the wheel conection. THe axles are not T bone shape but have a hexagonal shape at the end so its rounded off. I don't know if that was clear...... Anyway I ordered new axles and hubs (t bone this time) and will install a 10.5 engine and voila that should do the trick! Will let you know!
- Mad Racer
If you are putting a brushless you must get the Tamiya CVD kit for the FROG.
The Dog bone in the re re are crap in my opinion. Ok for stock motor but they fall out easy i found. All my Frogs have the CVD HOP UP. Well worth it.
My mate has a stock Fox with a Z Run 5.5 brushless and is just insane. Gearbox hols up just fine. His trick. New gears with a little ceramic grease on the gears.
Wow, that's a powerful motor for a Fox. How does it handle at such speed? Has your friend made any adjustments to the set-up or is it otherwise fairly stock?Mad Racer wrote: My mate has a stock Fox with a Z Run 5.5 brushless and is just insane. Gearbox hols up just fine. His trick. New gears with a little ceramic grease on the gears.
- Mad Racer
No stock as a rock. Replaced the rubber boots on the drive shafts to some 8th scale shock boots. A lot freer in the drive train.
A wheelie bar. Thats it. The Speedie sits up on the chassis where the driver is with the window on the sheel cut out to help cooling. No oil in the shocks. Just insane. Biggest pinion too.
- 566 Views
Last post by cooltoys
- 1604 Views
Last post by Bormac
- 722 Views
Last post by Mad Racer
- 2532 Views
Last post by Pepito
- 1716 Views
- 1759 Views
Last post by Boondocs
- 650 Views
Last post by muck
- 1573 Views
Last post by Bra84
