Local consignment score
Re: Local consignment score
I just got through replacing a bunch of parts on my Optima Mid because someone went nuts with super glue. No way to get that crap off.
Gary
If you are talking about chassis and plastic parts, acetone works well. Just soak them as you would rims. -Jeff
Good to know...thanks!Jay Dub wrote:If you are talking about chassis and plastic parts, acetone works well. Just soak them as you would rims. -Jeff
Gary
The only parts you would want to be careful with are the lexan bits. Not much you can do with those except sand and polish. -Jeff
- RichieRich
- Has thanked: 34 times
- Been thanked: 19 times
Current status. Just need to add some more decals.
I replaced the stealth with an RPM 2.65 conversion and the Factory Works shock towers with the ebay carbon fiber versions. Otherwise, it's pretty standard. Oh yeah, did the 2.2 wheel/tire conversion too.
- bearrickster
- Been thanked: 5 times
One time he was showing a kid how to start a model plane engine, puts duct tape over his knuckles:pancar wrote:Personally, I like the guys who Loctite EVERYTHING. Loctite on locknuts, on self-tapping screws, I even found one that had loctite on some e-clips! They are usually the same ones that use a half roll of electrical tape on the wires, but at least that's a step up from duct tape
In the words of Red Green:
"If the women don't find you handsome, they should at least find you handy."
"If at first you don't succeed, then use more duct tape."
"You cannot make a fine quality lager using Kool-Aid Technology ..."
"Duct tape is like the force, it has a light side, a dark side and it holds the universe together."
DUCT TAPE RULES!!
"take the duct tape and put that where the cut will be..."
- metallicats33
- RichieRich
LOL! I think they're a little overpriced, but their graphic was neat and it matched well. Plus, I love redheads. The wife is a redhead too.
- bearrickster
- metallicats33
- rc10johnny
- TUCRACEMAN
Sweet Rich! I really need to get busy and build another RC10.
~D
~D
No, I will not help you with your dorky short course truck…sorry, it’s against my religion. If it's not a 1/10 scale buggy...I don't care.
- RichieRich
I updated the pics above. I added the RPM suspension arms. How come they never tell you what parts are compatible? I installed all four suspension arms, then went to add the RPM gear cover and it DOESN'T FIT!! WTF?
Apparently, the RPM arms require the use of the longer rear hinge pins, no problem, got a set of those. The extra arm material gets in the way of using the RPM gear cover. Ugh, thank god I had a standard gear cover in the parts box.
- 452 Views
Last post by erichevy
- 905 Views
Last post by nvxwax
- 773 Views
Last post by DaveM
- 1470 Views
Last post by dcar513
- 30 Replies
- 1786 Views
- 852 Views
Last post by slotcarrod
- 1157 Views
Last post by bully
- 1201 Views
Last post by charlie_b
Users browsing this forum: carloco8, DotNetDotCom.org [Bot] and 53 guests
