Nitro Monster Beetle
- coxbros1
- Has thanked: 1975 times
- Been thanked: 1756 times
It's just mocked up, nothing is final...but this was the hardest part...rest will be downhill...gonna run the crap out of this thing! Goal is to make it look 100% stone stock
- MarkyDents
- Has thanked: 1364 times
- Been thanked: 512 times
Re: .12 Nitro Monster Beetle
Dude ! Holy poop !
Hey Cru ! Go balls out
- Has thanked: 946 times
- Been thanked: 563 times
Whoa! This will be awesome.. You can get aluminum gear cases and counter gears now for these.
-Brad
- coxbros1
Cool! I haven't researched any upgrades for these "space age" chassis trucks..but I will...I would like to keep it as stock as possible and see what holds up and what doesn't, then just buy what I need for reliability...the only switched part so far is a frog counter gear (the smallest one)...luckily I have an unbuilt Frog I can steal parts from!....and it has an MIP Ball diff in itBattleTrak wrote: ↑Sun Feb 18, 2024 5:15 pm Whoa! This will be awesome.. You can get aluminum gear cases and counter gears now for these.
- Frankentruck
- Has thanked: 1591 times
- Been thanked: 1774 times
Are you starting with a rere gearbox? The pin dogbone outdrives look like it is.
- juicedcoupe
- Has thanked: 231 times
- Been thanked: 1747 times
That is the MIP diff. It only works with re-re dogbones or CVD's. The rest of the gearbox parts interchange.Frankentruck wrote: ↑Mon Feb 19, 2024 9:17 am Are you starting with a rere gearbox? The pin dogbone outdrives look like it is.
- juicedcoupe
What did you do to the "pinion" section of the Frog counter gear to get it to work with the larger Blackfoot diff gear?
- Has thanked: 1032 times
- Been thanked: 488 times
- coxbros1
- coxbros1
I had to take out the MIP ball diff and pit in a stock Frog gear diff...tranny and clutch bell roll over super free!juicedcoupe wrote: ↑Mon Feb 19, 2024 10:01 amWhat did you do to the "pinion" section of the Frog counter gear to get it to work with the larger Blackfoot diff gear?
- coxbros1
Had to do an engine swap...the red head hit the body, didn't want to cut up the body...hope this lil O.S. CZ is up to the task!
Had to switch the MIP Ball Diff for a Frog Gear diff...tranny/clutchbell super free...zero resistance
Also had to relocate the right rear shock to clear the engine mount...it will have brakes but that's on down the road
- juicedcoupe
Did you do the "Frogshot Mod" to it?
- coxbros1
I don't know what that is..lol!
- 28 Replies
- 5438 Views
Last post by alien3t
- 587 Views
Last post by breck
- 701 Views
Last post by Medved
- 639 Views
Last post by R Cane
- 2182 Views
Last post by j-sou
- 867 Views
Last post by MelvinsArmy
- 1035 Views
Last post by uniquenamehere
- 2084 Views
Last post by Rizzo
Users browsing this forum: jwscab and 6 guests
