Will clutch bells from other makes/models fit the Nitro Hawk/Buggy/Street, or are their long crank clutch bells proprietary?
For example, will #4120 fit (bell for n rustler/pede), or a bell for 10GT?
Guessing 10GT used standard sized bearings and is likely a no, but what about others that used metric?
Traxxas Clutch Bell
- Has thanked: 824 times
- Been thanked: 2419 times
Re: Traxxas Clutch Bell
Edit- I’m wrong. Ignore
Factory Works website
- DennisM
- Has thanked: 30 times
- Been thanked: 64 times
I guess it depends of which engine You´re running.
The following part numbers should fit the TRX pro 0.15 - according to Traxxas.
If You´re running a 0.12, You´ll need a bearing adapter - information found on Traxxas support site
4116 clutch bell 16t
4118 clutch bell 18t
4120 20t clutch bell
4122 clutch bell 22t
Gone fishing
- jkelm24
- Has thanked: 20 times
- Been thanked: 77 times
Sorry, should have clarified that I'm using the Image .12, but the same bell part numbers are used with all N Hawk long crank engines (Image, TRX .12, TRX .15).
Traxxas diagrams all show the same 20T bell part number for .12 and .15 long crank (#3120), but have #4120 listed for short crank applications (n rustler/ped, etc). Both use metric bearings, so I'm wondering if there's a difference in clutch interface dimensions (bell ID, depth).
Basically just looking for anything out there that might be available and compatible.
- 3985 Views
Last post by Dirtcar75
- 1591 Views
Last post by TheSpeedway
- 179 Views
Last post by the13bats
- 353 Views
Last post by SteveK
- 1446 Views
Last post by Chewbacca
- 918 Views
Last post by myfordcnc
- 1322 Views
Last post by askbob
- 597 Views
Users browsing this forum: No registered users and 22 guests
