6 gear trans article (June 89’ RCCA)
- MarkyDents
- Has thanked: 1364 times
- Been thanked: 512 times
Thought this was a great read, figured others may appreciate it as well.
Click pics for better resolution Who do you race for ?
Hey Cru ! Go balls out
- RogueIV
- Has thanked: 1119 times
- Been thanked: 460 times
Re: 6 gear trans article (June 89’ RCCA)
It's a good reminder that Team Losi used to be just an aftermarket parts supplier. Still feel weird to see a giant Team Losi decal on an RC10 though.
It's interesting to read, a lot more effort was needed back then to properly rebuild a tranny, most stuff now you just need to assemble it, no filing and hand fitting gears.
- MarkyDents
One of the things I appreciated most from this article was the clear explanation of what and why the aftermarket parts were created for. For instance the long Trackmaster diff shaft, one of mine has it and I yes of course the longer threaded end makes simple clear sense but the need for the screw on the opposite side kind of perplexed me until now
- RogueIV
That's the one thing that irritates me about some other how-tos. Knowing the "why" is more important than the "how" In my opinion. It gives the reader a way better understanding of the mechanics involved.MarkyDents wrote: ↑Sun Dec 11, 2022 2:15 pm One of the things I appreciated most from this article was the clear explanation of what and why the aftermarket parts were created for. For instance the long Trackmaster diff shaft, one of mine has it and I yes of course the longer threaded end makes simple clear sense but the need for the screw on the opposite side kind of perplexed me until now
- juicedcoupe
- Has thanked: 231 times
- Been thanked: 1747 times
I have one as well. I always figured that the screw was for simplifying assembly and disassembly for maintenance. Having to constantly deal with a captured E clip would get old. Simply loosening the diff and removing the screw allows quick disassembly of the transmission.MarkyDents wrote: ↑Sun Dec 11, 2022 2:15 pm For instance the long Trackmaster diff shaft, one of mine has it and I yes of course the longer threaded end makes simple clear sense but the need for the screw on the opposite side kind of perplexed me until now
If the screw wasn't tight, it would likely back out. Of course, 3/16" OD shims could be used.
- 1024 Views
Last post by Brandon G
- 803 Views
Last post by SteveK
- 31 Replies
- 3611 Views
- 1867 Views
- 39 Replies
- 6935 Views
Last post by wyldbill
- 2140 Views
Last post by Erich Reichert
- 19 Replies
- 6166 Views
Last post by SteveK
- 5088 Views
Last post by jcwrks
