2.2 wheels on Ultima rere
- Brocklee
- Has thanked: 17 times
- Been thanked: 12 times
Has anyone had any luck running 2.2 front wheels on the Ultima rere? Ive got a handful of rc10 front wheels I'd like to use but I'm not sure if anyone has had any luck adapting them to the Ultima. Ideally I would like to start running this at my local outdoor track
Cars: kyosho raider, rc10 ce, kyosho ultima pro xl, lazer zx, inferno mp s, losi xxt, xx4we, rc10t3, kyosho zx5 sp, rb6, zx6, rb7ss, zx7, mp10e, crc xl, rc18r, tamiya trf 801xt.
- juicedcoupe
- Has thanked: 231 times
- Been thanked: 1747 times
Re: 2.2 wheels on Ultima rere
If your wheels use 5/16 OD bearings, simply swapping them for 8mm bearings should work with some shims.
I'm not aware of a bearing that would fit the 3/8 bearing wheels. You might also able to find some 3/8 OD tubing that has the correct wall thickness to make some adapters.
- Has thanked: 824 times
- Been thanked: 2419 times
This was pretty easy bitd when AE wheels were 3/16 x 5/16 flanged- the 5/16 bearing hole was fine with the stock 8mm bearing pressed in. Unfortunately when they went to the 3/16 x 3/8 bearing hole there isn’t a metric size that is close enough. You would would need to have front axles made for 3/16 bearings to do it right. Or see if you can find someone to machine a 4mm to 3/16” adapter sleeve.
Factory Works website
- Frankentruck
- Has thanked: 1591 times
- Been thanked: 1774 times
K&S 8129 brass tubing looks like the OD and ID might be perfect to adapt 4mm axles up to 3/16".
- Brocklee
Hmm sounds like I need to get off my lazy butt and make a set of new axles. I've got a small lathe in the garage but it's disassembled from our latest move. On the bright side once I have my lathe put back together they look extremely easy to make
- juicedcoupe
I had some K&S #5074 assorted tubing. The 3/16 tubing in that pack fits pretty well. I checked it on a new Kyosho axle and 3/16 ID bearing.
The fit in the bearing was snug. The fit over the axle was a touch loose, kinda like a bushing. I'd probably put some Locktite between the sleeve and axle.
The tubing came from the local Hobby Lobby store.
- Been thanked: 4 times
For my Scorpion rere, I used a 4mm bullet with the solid end trimmed off to make a sleeve that fits over the 4mm axle and accepts 3/16 id bearings. The bullet connector has a tick of play on the axle but if you're careful cutting it can be secured by the nut. The play is nothing compared to the slop in the scorpion front end!
- Has thanked: 19 times
- Been thanked: 16 times
I'll be trying to fit up 2.2's on a re-release ultima I picked up today at lunch. I have a set of wheels from a Tamiya sand viper that will work. I think trf201 front wheels would work also just hard to find. I was thinking the 4x8x3 flange bearings would work but then I see the JC wheels I ordered are 3/8 bearings grrrrr
- terry.sc
- Has thanked: 6 times
- Been thanked: 82 times
For modern wheels most of us used to use Turbo Scorpion wheels, but now JC Racing Products make 2.2 wheels specifically for the Ultima https://www.jcracingproducts.co.uk/wheels/kyosho-2wd-ultima76jimmy wrote: ↑Wed Feb 09, 2022 7:27 pm I'll be trying to fit up 2.2's on a re-release ultima I picked up today at lunch. I have a set of wheels from a Tamiya sand viper that will work. I think trf201 front wheels would work also just hard to find. I was thinking the 4x8x3 flange bearings would work but then I see the JC wheels I ordered are 3/8 bearings grrrrr
Been messing with my Ultima again. Was able to fit a Traxxas Bandit front end on very easily without having to butcher any parts in the chassis.
Now I'm full hex and track width is about 9-3/4" with losi wheels.
- Regular Member
- Has thanked: 44 times
That's what I use on mine and they work perfect
RC10 / Ultima / Optima mid/ Javlin
Novak / Reedy/ Hobbywing
- Has thanked: 14 times
- Been thanked: 14 times
Mini E-revo rims are perfect on the rear (Traxxas 7171), they have the same offset as the scorpion ones, i also tried the jconcepts rulux (3333B) ones and they work just as well
I ended up doing a similar thing but using Optima front knuckles and hubs. it widens the front end, and adds front caster which helps the car but the inner ball stud needs to be moved higher on the shock tower to correct the roll centre
- 1839 Views
Last post by Nige55
- 733 Views
Last post by Sparbolt
- 808 Views
Last post by jasmar10
- 1683 Views
Last post by Sprocket
- 434 Views
- 1451 Views
Last post by vwjuice
- 1407 Views
Last post by cas22
- 808 Views
Last post by ProXL
