Bolink Eliminator Rebuild
- Regular Member
Have the Eliminator fully assembled and now thinking ‘tronics. More from the motor / battery aspect as I have a Spektrum DX5C so I’m just going to get a receiver. I was wondering if anyone has gone brushless/LiPo on one of these models. My concern is it won’t be able to hold traction. Thought?
- coxbros1
- Has thanked: 1975 times
- Been thanked: 1756 times
Re: Bolink Eliminator Rebuild
If u stay in the 21.5 to 17.5 range it should be fine.
- GeneralZod
- Has thanked: 148 times
- Been thanked: 153 times
Also you would need to reduce the spur gear tooth count and increase the size of pinion if going brushless. Even with brushed motors, these can move pretty fast and will spin out without proper traction. Like driving on ice.....
- KidAgain
- Has thanked: 288 times
- Been thanked: 198 times
In situations like this I would buy an ESC that has lots of options for tuning, are you going to run foam or rubber tires?
I can go from popping wheelies at the hit to silky smooth launches with a couple of clicks also I can turn the heat up mid range to top end, some ESC’s are so tunable that you can literally tune the braking off throttle through turns.
Gone: RC10, Jrx-2 and Jrx-t
Current: 3 SC10 first gens, 3 SC10 Street Outlaw's, 12 RC10 DS’s, Carbon RC10T, RC10LSS,RC10L, RC10 Graphite,RC10 B44
- 4036 Views
Last post by dreambmx
- 959 Views
Last post by bladeszx2
- 1447 Views
Last post by GJW
- 1065 Views
Last post by Brandon G
- 940 Views
Last post by USA-1
- 937 Views
Last post by Dumanyu
- 1784 Views
Last post by GeneralZod
- 791 Views
Last post by TheDiamondOne
