Shaft drive Clod?
Forum rules
Keep it all things Clod!
- SFC K
- Has thanked: 47 times
- Been thanked: 9 times
Shaft drive Clod?
A little project I have been working on this winter.
I am using a Clod chassis with a twist, and that is I am installing center mounted transmission with Gmade R1 portal axles. Transmission is out of a SCX-10 with the upgraded 32p gears and dual slipper. Plastic links are pulled from my old Axial Honcho with two on each corner with a custom made pan hard bars front and rear.
Today I received my 2.2 RC4WD Tractor tires for it and mocked them up on some Losi 2.2 crawler wheels. Not going with these but wanted to see how they looked. I also had a complete Tamiya Ford F350 body laying around so I painted that up and detailed it for this build.
I have some more work to do on it but it is getting there.
Jeff
- Has thanked: 10 times
- Been thanked: 447 times
Re: Shaft drive Clod?
looks great, checked it out on clod talk the other day.
how's the suspension travel with panhard bar the length that it is? seems like it wants to be a bit longer.
- SFC K
Thanks! It will travel all the way down to the spring cups on the bottom of the shocks. I had to switch out the shocks for some Gmade shocks. The Traxxas Big bores really limited the amount of travel due to the chassis being so light and the shocks themselves were to stiff.
For mud duty and some light trails it should preform well, I hope. With these tires it has just over 2.5"s of clearance under the pumpkin.
Jeff
- TRX-1-3
- Has thanked: 1399 times
- Been thanked: 764 times
Dude that is totally sweet. The F-series with the larger tires is doing it for me. Nice mash-up.
- Has thanked: 14 times
- Been thanked: 57 times
- matt1ptkn
- Has thanked: 80 times
- Been thanked: 132 times
Wow. If I had the cash, I'd ask you to build one for me. This truck just has that look. Very nice.
Matt
- RC10th
- Has thanked: 40 times
- Been thanked: 1018 times
That looks almost identical to a purpose built mud truck.
- Mr. ED
- Has thanked: 58 times
- Been thanked: 56 times
- Diamond Dave
- Has thanked: 567 times
- Been thanked: 103 times
- RC10th
Looking good.
Time to go do this, Go Air Mundy !!
[youtube]HAdGy44mGjo[/youtube]
- SFC K
Cool truck in that video! Man he was hauling!
A couple pictures from my snow ( **cough** Ice) run. The high today was 3 degrees but with the wind it is more like -17.
Any way truck runs well and does great out on the ice snow. Plenty of traction, but it was so cold, my servo started to slow way down from the cold. Never had that happen before, but this one has an all aluminum case and I'm sure the grease inside froze maybe?
Anyhow, A couple pictures.
And a shot with Excaliber.
Jeff
- Been thanked: 22 times
- 905 Views
Last post by juicedcoupe
- 603 Views
Last post by slow_jun
- 420 Views
Last post by Typpo
- 171 Views
Last post by Snaab9-2
- 916 Views
Last post by Headling
- 820 Views
Last post by DennisM
- 93 Replies
- 19636 Views
Last post by Jeep-Power
- 892 Views
Last post by LaserRC10
Users browsing this forum: Brandwatch [Bot] and 16 guests
