Ok I know the Samurai is the gun Marui buggy.
I do want one but the price is high for them.
What is the difference from the Shogun and Ninja.
Are they the same platform or are different altogether.
Any Help much appreciated.
Marui Shogun And Ninja?
- Mad Racer
- prp
- Been thanked: 11 times
- Has thanked: 7 times
Re: Marui Shogun And Ninja?
PRP is correct obviously.
The Shogun and Ninja are actually even better cars to drive when set up properly - alot more reactive, but you would expect that from a shaft drive with a battery down the middle.
The Samurai is a completely different design to just about any other 4wd (spaceframe) - with perhaps the exception of the Playtron cars. Not many 4wd spaceframe chassis cars were made. At the time Marui were not marketed very well, suffering the fate of alot of other smaller brands BITD. It was only after that some drivers realised the potential of the chassis, sadly, the timing was all wrong and technology had moved on. The Samurai deserves its reputation as a great car though - as it drives exceptionally well and is surprisingly free in the drivetrain area. Damn good work for a chain drive back then.
Cheers
Darryn
Cheers
Darryn
- Mad Racer
Thanks for the comments guys.
Darryn doe they suffer from gearbox drivtrain problems at all???
Thanks.
Thanks.
The Samurai was known for a weakness in the rear gearcase moulding - however the gears themselves we very reliable.
The Shogun and Ninja were prone to wear out the bevel drives at the end of the main shaft - particularly at the rear, this was mostly a problem running mod and or seven cell though. I ran one a few times in stock and nver had a problem (borrowed car).
Knowing you - you are as bad as Jason was and wont be happy unless you are going down the straight at "Mach 5 with your hair on fire!!" So perhaps the Ninja is OK - just stock up on some bevel gears.
Worth having a look at though - as for vintage racing here in Aus - its a perfect car for mild mod - even better stock class. Relatively cheap parts and seem to come up quite a bit on eBay.
Cheers
Darryn
Cheers
Darryn
- 93 Replies
- 4356 Views
Last post by silvertriple
- 1785 Views
Last post by purpletimbo
- 50 Replies
- 6530 Views
Last post by GeneralZod
- 3212 Views
Last post by Mr. ED
- 2032 Views
Last post by caesar
- 1415 Views
Last post by RedScampi
- 47 Replies
- 6013 Views
Last post by Frankentruck
- 871 Views
