Mugen BULLDOG mods.
- besty22
Re: Mugen BULLDOG mods.
PRP. From memory there is a small grub screw which controls hardness of the air damper. It is in the damper mount. I will confirm this at home tonight.
Respect - Hard Earned but Easily Lost
- prp
- Been thanked: 11 times
- Bormac
- Has thanked: 21 times
I have recently stripped down both of the Mugen Bulldog's which I have left wanting to get both these cars sorted out once and for all. What I mean by this is I have had some ideas that I wanted to implement the same modifications to both cars. I figured I'd post up some pics for you to look over.
Clearly I am not an engineer nor am I an expert machinist. I have set about doing the best I can with the tools and materials I have available to me. What this means is that you also could use some of these mods on your car if they are of interest you.
Basicaly I didn't want to modernize my cars but rather use some ideas that the guys did or could have done back in the day when these cars were out on the race track.
Belt tensioning system.
From experience anything more than an old stock motor and nicads would produce belt slipage. For me the drive componants are too hard to find now days and once teeth are rounded over it's common even for new belts to slip and continue wear on the belt pulleys. I have experimented with a few ways to add a tensioning sytstem but for me this one has worked the best.
The concept was simple, create a slot in each side of the alloy chassis plate which can allow a single M3 screw to slide back and forth. On the inside of the chassis a pair of flanged bearings are fastened onto the M3 screw allowing the bearings to roll down over the top (flat side) of the belt. The adjustment slots allow enough room to release and add tension as required. It's a simple system that works well for me. I have been running a 12T brushless system and there has been no slip at all.
- Bormac
I'm still yet to experiment with the centre ball diff. I have been running it locked up.
- Bormac
- Been thanked: 289 times
Nice mod, Jason. You might consider swapping out the washer + nylon lock-nut for a flanged lock-nut, that should prevent any up-down slippage--if that ends up being a concern.
- prp
Hi Jason
Normally, you must put the belt tensioner under for the rear belt and on the belt for the front.
The belt force more on the belt tensioner on yours...
- Bormac
Hi Marc. Thanks for the suggestion as it is a good one. I'd prefer not to use a serrated nuts though as this could create a 'memory' spot on the slot. The washers I've used on the out side are quite sturdy and you'd be surprised just how tight these adjusters do up. I've been running a Hobbywing brushless 13T system and I have not had any trouble yet.Coelacanth wrote:Nice mod, Jason. You might consider swapping out the washer + nylon lock-nut for a flanged lock-nut, that should prevent any up-down slippage--if that ends up being a concern.
I do appreciate your input though.
- Bormac
Thanks for your suggestion Pierre. By chance might you have any images of what you are referring to? After studying my Tamiya 501X's drive train I realised the belt tensioners prevented the belt skipping on the approach side of the belt and pulley. Essentially I wanted to do something similar rather than just tension the belts at their middle. Whilst I could not quite fit my pulleys in as close as the 501's I did what I could to get the job done.This has worked well for both me and my pal 'Besty'. Both our Bulldogs had issues with belt slippage under load and braking whilst out on the race track. After this system was implemented on both of our cars we've not had any more issues.prp wrote:Hi Jason
I do welcome any suggestions and I'm very keen to learn what other systems have and are being used.
I love modified Bulldogs
- prp
Like on the K1 Schumacher, for the front belt the tensionner in on, and for the rear belt, he is under.
When your motor run the spur gear the front belt is tight on the under side, and the upper side is relax,
for the rear belt it's the opposite.
If you put the tensionner like you installed, the belt forced more on the tensionner.
Block the front diff with 1 hand, and turn the diff forward with the other hand and see the upper belt is relax.
On the 501X the ball bearing are directly on the pulley and you have in more excentric to tight the belt.
I see on mine too , the center diff pulley are not round...
- Bormac
I get what you mean now Pierre. The belt feeds onto the pulley straight rather then under load from a tensioning bearing. Ofcourse I am no expert on this kind of stuff but I located my tensioner bearings at those locations because I thought that would prevent any slack from the belt going onto the pulley.
If someone else wants to try Pierre's concept out on their Bulldog I'd very much like to see how that goes aswell.
- 1183 Views
Last post by urban hype
- 52 Replies
- 8854 Views
Last post by Mr. ED
- 1322 Views
Last post by saga101
- 1213 Views
Last post by Bormac
- 1353 Views
Last post by Mr. ED
- 1506 Views
Last post by HotRodJosh
- 1616 Views
Last post by Dadio
- 3354 Views
Last post by emerson_shih
