Axle carrier configuration?
- Regular Member
OK. I recently bought a gold pan buggy off the local classifieds. I do RC planes and helos, but haven't had a buggy since my Fox 20 years ago.
I read up here and elsewhere on how to convert the back wheels.
Here is the list I found that I went off of for my order to Tower Hobbies, and then links to the stuff I actually ordered.
Axle: Associated 7378
http://www3.towerhobbies.com/cgi-bin/WTI0095P?FVSEARCH=ASCC7378+&search=Go
Bearings: Any 3/16x3/8 bearing, but Associated 6906
http://www3.towerhobbies.com/cgi-bin/wti0095p?FVPROFIL=++&FVSEARCH=LXBMG8&search=Go
Spacer: Associated 7377
http://www3.towerhobbies.com/cgi-bin/wti0095p?FVPROFIL=++&FVSEARCH=LX2983+&search=Go
Shim: Associated 7368
http://www3.towerhobbies.com/cgi-bin/wti0095p?FVPROFIL=++&FVSEARCH=LX2976+&search=Go
Pin: Associated 6375
http://www3.towerhobbies.com/cgi-bin/wti0095p?FVPROFIL=++&FVSEARCH=LX2563&search=Go
Rear Wheels: Associated 9491
(chose Nitro Evader wheels based on reading this forum...)
http://www3.towerhobbies.com/cgi-bin/wti0095p?FVPROFIL=++&FVSEARCH=LXFFG3+&search=Go
Rear Tires: Any modern rear buggy tire.
http://www3.towerhobbies.com/cgi-bin/wti0095p?FVPROFIL=++&FVSEARCH=LXCXT3+&search=Go
One thing I missed was the flanged vs unflanged bearings, and my LHS has those.
The manual I have found just shows the plane bearing race type axle carrier. I'm trying to get everything to go together right.
Do I need two bearings per carrier?
Where are the spacer and shims supposed to go, respectively?
- Has thanked: 29 times
- Been thanked: 981 times
Re: Axle carrier configuration?
you need 2 bearings per hub. the shims would usually go on the inside...... if you even need to use any of them.
- Regular Member
So the spacer is supposed to go between the two flanged bearings? The reason I ask is that is seems like it is a little long (though I don't have the flanged bearings yet...)
The purpose of the shims is to bring the stub closer to the dog bone and get the wheel pin in the right place?
you shouldn't even need those spacers.
the shims are just to take the slop out of the axle. if they need them, add them to the inside.
- Regular Member
- JPAE07
Mighty dang expensive. Most you should pay for those is $1 a piece.
Try Avid
http://www.avidrc.com/
Try Avid
- Been thanked: 12 times
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=360145901927
12 ae bearings for $8 shipping is $9, but they combine shipping and have lots of other deals like $3 pairs of 2.2 bugy rear tires
- 905 Views
Last post by Percymon
- 887 Views
Last post by JosephS
- 2244 Views
Last post by mvelarde890
- 1091 Views
Last post by Group B
- 1467 Views
Last post by SUPERDAD
- 570 Views
Last post by broodenburg
- 551 Views
- 29 Replies
- 2665 Views
Amazon [Bot],
Bing [Bot],
sixdub and 3 guests
