My Yokomo's
Alex B
Has thanked: 23 times
Been thanked: 47 times
My Yokomo's
Post by Alex B »
Few pics of two of the three yokes I currently own. Better pics to follow including a newly restored works 91
I just got the pavidis in the post this morning and its pretty much in excellent condition, but I will rebuild it when i get the chance .
The other Yoke is a works 92 with associated shocks, 93 rear shock mount and steering set up. The works Yoke has been fitted with modified MR4 BC front hubs and carriers for extra strength. I will be debuting it at a local club after a 20 year absense 8)
If anyone can help i am looking for a slipper pad and trust race, or could anyone tell me if the original RC-10 Stealth pad would fit a Yoke slipper?
Thanks
:shock:
Alex B
Re: My Yokomo's
Post by Alex B »
Quick update on the YZ10
I gave it a quick rebuild last night, the only things changed were the rear bulkhead, the steering ball joints, some metric nuts and bolts for the assoicated shocks, the o-rings for the shock mounts, half of the steering parts and most of the horrible phillips screws.
In all, really pleased but it did cost me a small fortune . Now i've got to decide wether or not
I put it on the track.
:shock:
bscotti
Re: My Yokomo's
Post by bscotti »
wow, those look great!
What tires did you put on the Pavidis? I don't recognize the tread pattern.
Classics rule, moderns drool
Alex B
Re: My Yokomo's
Post by Alex B »
bscotti wrote:wow, those look great!
The tyres at Hotlaps TF-51 on the rear and TF-510 on the front and have quite a soft compound.
:shock:
fakiee
Re: My Yokomo's
Post by fakiee »
The stealth teflon clutch pad will fit the yoke slipper, so will the spur gear mount (if memory recalls).
Alex B
Re: My Yokomo's
Post by Alex B »
fakiee wrote:The stealth teflon clutch pad will fit the yoke slipper, so will the spur gear mount (if memory recalls).
Thanks
:shock:
Return to “Yokomo Forum”
