vintage rc10 shocks
liltexmp
vintage rc10 shocks
Post by liltexmp »
New here and was just curious about what is the deal with the shocks that have bleed off's on top with tube running between them? I got a set on an ebay buy and haven't seen anyone else with those types. It is an A stamp chassis w/Andy front and rear arms. Thanks for the help.
Has thanked: 3708 times
Been thanked: 1980 times
Re: vintage rc10 shocks
liltexmp wrote:New here and was just curious about what is the deal with the shocks that have bleed off's on top with tube running between them? I got a set on an ebay buy and haven't seen anyone else with those types. It is an A stamp chassis w/Andy front and rear arms. Thanks for the help.
Are you talking about something like these?
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXKVH8&P=7
It's hard to tell if that's what you mean, but if it is they are normally used on large or heavy monster trucks. They look cool, but I'm not sure exactly why they are made that way. Obviously must have something to do with oil displacement under a heavy load. I'm no expert though.
RER40
Post by RER40 »
THUMBS, those are reservoir shocks -- they've made them for all sorts of vehicles for years, concept was brilliant but didn't really work on anything...........
......... but I do remember seeing something once where the shock caps had a bleeder valve and a tube to run between the shocks -- but it was just another one of the over-engineered bits they came out with back in the day, that was hot for about half a second.
Neat find either way. :mrgreen:
I remembered that too, but thought I must be wrong because it seems like kind of a stupid concept. That's a long way for it to travel. lite, maybe you can post a pic when you get a chance. It would be cool to see. If it was an RC10 application it is likely posted here somewhere. Maybe another member knows. :wink:
I have no idea what happened to that last post. sorry :oops:
RER40
Post by RER40 »
try the EDIT button............works great :lol:
RER40 wrote:try the EDIT button............works great :lol:
Yeah, but then I couldn't embarrass myself as often....
:P
RER40
Post by RER40 »
Image Image Image Image
liltexmp
Post by liltexmp »
Been thanked: 1319 times
that's what you would call a "home made" setup.
liltexmp
Post by liltexmp »
thanks for the help I'll have to get some new shocks for it then. I was also wondering it the steering linkage was homemade?
I also got a B stamp car w/ stealth trans that I'm going to use the white parts to make the first one look better.
THUNDERSTRIKE1
Post by THUNDERSTRIKE1 »
You just need new shock caps not w 8) hole new shocks.Don
Twiceblown351
Post by Twiceblown351 »
Why? the B car the newer and better car for runing and racing. The stealth is 10 times stronger then that old 6 gear,
Twiceblown= 93 F150 Lightning
393 and two turbos @ #10Psi
= 10.90@126 in street trim
liltexmp
Post by liltexmp »
The B car is in worst shape than the older one, but has all white parts. No other reason really
Users browsing this forum: No User AvatarMojeek [Bot] and 3 guests
