Setup needed.
Setup needed.
Anyone have a good racing setup for a gold pan?
My car will have the a&l trans,wide front end with Andys front arm holder,rear b2 cvds (2.2 wheels) and stock everything else. The rear upper link has been re-drilled already to make it longer.The pack will be front to rear (ni-mh). Could use a good spring/oil/link setup. Also any "must have" mods to make the car competive would be nice.
Were there any gold pan cars that were able to hang with the graphite rc10s an or jrx's at last years nats?
Thanks.
Thanks.
- Has thanked: 36 times
- Been thanked: 1319 times
Re: Setup needed.
this was mark's setup from the nats on his tub car. he finshed second. tim's tub car was setup very similar from what i remember him saying and he won.
http://www.rc10talk.com/viewtopic.php?f=35&t=6600
- Chamberlain
Re: Setup needed.
The best set ups were when we ran #2 pistons drilled one whole with #55 to make it a 1/2 piston.
All the way around with 27 or 30 all around.
Green Rear springs.
Black front springs.
4 .032 limiters in the back.
1-2 .032 limiter in the front.
25deg caster blocks.
Inline axles.
Middle holes in the shock towers and outside on the arms.
PM me if you need any other information.
I hope this was helpful.
Green Rear springs.
Inline axles.
Re: Setup needed.
that' s the setup I always ran, If you run a lipo probably put 1 oz of weight somewhere under the battery.
Mark
- 972 Views
Last post by yellowdatsun
- 584 Views
Last post by Rustbucket
- 962 Views
Last post by JK Racing
- 1774 Views
Last post by popboy905
- 1780 Views
Last post by village idiot
- 20 Replies
- 2675 Views
Last post by Bft450
- 411 Views
Last post by TViz
- 527 Views
