Graphite parts I.D.
Old Twister
Graphite parts I.D.
Post by Old Twister »
I got this about 6 years ago at a swap meet then tore it apart and just shelved it. This had no tranny in it at the time. Also in the deal was a gold pan with the old tranny, but it has the same front arms as below, and a complete front end with the older block style arms
So my questions are
1. Was this chassis drilled out for a stealth or did it come that way?
2. Are the shocks and front shock tower original?
3. What are all the extra holes for on the outer edge?
4.And what car might the gold pan be?
Thanks for any info
David
Been thanked: 1319 times
Re: Graphite parts I.D.
what you have there was a graphite team car.
1) it was drilled for the stealth from the factory.
2) it looks like your missing a front, and a rear shock. but, they are correct for the car. the front shock tower is not correct. that was made by JG.
3) the extra holes are to mount the battery cups so the battery runs across the chassis. one is countersunk for the antenna mount.
4) the gold piece is the motor plate, and the rear motor guard.
Old Twister
Thanks for the info. Actually I have the other 2 shocks but I didnt put them in the picture. I guess since its pretty beat up I will just build it as is.
David
Users browsing this forum: No User AvatarGoogle [Bot] and 8 guests
