looking for slingshot parts and info
racerj79
Post by racerj79 »
Hi! looking for some parts/manuals/aftermarket parts for the slingshot. if someone has anything please let me know. thanks lots
highwayracer
Been thanked: 6 times
Re: looking for slingshot parts and info
Post by highwayracer »
To be honest with you, I haven't seen too many after market parts for the slingshot. Kyosho has the following:
universal drive shafts
different wheels and tires
the car already came with gold shocks
ball diffs used on the lazer
car already had bearings
So, the only significant change i can think of would be to replace the suspension arms and carriers with the ones found on the lazer. The slingshot suspension was optima based.
You can probably replace the stock bellcranks with a better unit. The other item I replaced was the spur gear. I modified a losi profiled spur gear to work. Other than that, there's not much you can do unless you go really custom (machine an aluminum motor mount).
Regards,
highwayracer
Mr. ED
Has thanked: 62 times
Been thanked: 62 times
Post by Mr. ED »
mmm, that's a tough one to find parts for. Some parts are easier though as they are shared with other models like the optima mid.
Put up a picture of what you have already, list what you need and in which state.
To add to highway racers post ( which he pushed in while I was typing the above) there's some different sized spurgears from Trinity and others, and spurgear adpters to allow mounting 48dp standard spurs. All intended for the mid, but compatible.
modern additions could be cvd's of the ultima RB5 and 2.2 inch wheels (llok for the ones with bigger offset). A homemade chassis would help to: the original is just black coulored epoxy , not graphite, so it's rather souple.
Oh, and read the BuySellTrade section entry requirements
minimini
Location: KWS@Hong Kong; 3.5 hours' trip to meet tiger1 and only 7,777 miles from Doug
Been thanked: 11 times
Post by minimini »
Lazer ZX front shock tower can be used in this car too.........you need front shock tower x 2 for both ends.......... :)
farktheworld2007
Post by farktheworld2007 »
racerj79 wrote:Hi! looking for some parts/manuals/aftermarket parts for the slingshot. if someone has anything please let me know. thanks lots
Hi i may have some parts, not that much.
Is that a kyosho OR number???
mrlexan
Post by mrlexan »
Mr. ED wrote:Oh, and read the BuySellTrade section entry requirements
Guys, exchange of info is fine, but please be careful, we are walking that thin line of the BST rules. Any questions or comments, let me know. Thanks.
Jay
www.gojammedia.com
racerj79
Post by racerj79 »
thanks guys. i just found someone with a slingshot and a ton of parts for 50.00. I think this form is good luck because he also had a mid with even more parts for 60.00. i think i'm set for a while I'v got to go though a lot of boxes. may take me a while. I'll keep you guy updated on the slingshot build. I do need to finsh it soon the local dirt oval is running a dominator class and they need a kyosho car in there to mix things up a little. :mrgreen: P.S sorry! I will stick to form rule next time.
racerj79
Post by racerj79 »
HI GUYS! I just read your buy and sell rules. They are a little hard but I bet you guys have your resons. Anyways I'll keep posting and if anyone cares keep you updated on the vintage oval cars I'm bulding. I have the slingshot and a grandmotorsports jrx2 huger dirt oval car and 3 rc10 vintage dirt oval cars all being bulit none done. these are the cars from when I first stared in the 80's. So thanks guys and I'll be picking your brains for more info in the future.
Mr. ED
Post by Mr. ED »
Make sure to put up some [ics of the MID also; especially if it is a bit different from stock.
I've started working on mine yesterday and it sure is going to be 'off the beaten path'
Return to “Kyosho Forum”
Users browsing this forum: No User AvatarAmazon [Bot] and 25 guests
