Setup questions
General info, Q&A.
arf
Been thanked: 7 times
Setup questions
Post by arf »
I run my gold tub on a flat parking lot and considering decreasing front caster and rear toe from stock.
1. My spares include #6366 (1.5 deg.) rear hub carrier which gives 3 deg. toe in when used with the stock #6360 suspension mounts. What does the original #6365 rear carrier give? The old manual doesn't say. Also of interest is that my manual for the RC10 graphite shows the #6366 carriers are standard for that car. So the graphite car had different rear toe?
2. I also have a couple of #6214 (20 deg.) front block carriers, but how much caster does the original #6213 give?
Hope that made sense. Thank you humbly.
Re: Setup questions
the 6355's are zero degree.
when the widetrack cars came out they went to the 1.5 hub carriers.
the 6213 castor blocks were 15 degree.
arf
Re: Setup questions
Post by arf »
scr8p wrote:the 6355's are zero degree.
Thank you, I assume you meant #6365 are zero degree.
Re: Setup questions
yup, 6365. sorry about that.
