No harm in asking right?
I bought this fire nozzle off ebay mainly because we don't have anything like it here. What I want to know is how does it fit to the hose?..there's got to be another piece right?..
- Attachments
- 629f_1.jpg (13.51 KiB) Viewed 855 times
- civilguy
- Has thanked: 3 times
- Been thanked: 14 times
Re: No harm in asking right?
The top looks to be female threaded end. Do your hoses down under not have the male threaded end connectors?
http://www.tcw-web.com/Products/Hose_Tubing/Hose_ends__qd_fit.htm
Jeff
Jeff
No 99% are like the picture below. I liked the idea of a mini fire nozzle..so the connector you have is the most common over there?
- Attachments
- G1051_12mm.jpg (22.02 KiB) Viewed 832 times
- civilguy
I think most hose ends in the US are the threaded male end connectors like the top picture in the link I posted. They are usually crimped on when you get a new hose, but once they break/leak you can cut off the end and replace with the pictured one. Then you would need a hose clamp on the hose. Then it will probably still leak.
Obviously one end is male and the other is female....
Here's links to Lowe's (a hardware chain here): http://www.lowes.com/lowes/lkn?action=productDetail&productId=34767-104-A680/PBGH10
Jeff
Jeff
- Halgar
- Has thanked: 139 times
- Been thanked: 172 times
If you're looking for a quick clip, then yes, you'll need more connectors to make that happen. As for just a standard old "fire nozzle" that attaches to a hose, that's what you previously pictured.tizeye wrote:No 99% are like the picture below. I liked the idea of a mini fire nozzle..so the connector you have is the most common over there?
I can't speak for there being an IHT (International Hose Thread ), but I do know there's an IPT (International Pipe Thread )> I would suspect that hoses are similarly threaded around the world.
I went to the local hardware chain and showed them..they couldn't help but they did suggest trying an industrial hose manufacturer...
Users browsing this forum: Ahrefs [Bot] and 13 guests
