OLD 4 stroke motor
OLD 4 stroke motor
Got a old 4 stroke motor from the early 80s i beleive, slide valve carb, has hp marked on the head and carb, has fc 25 on the case, any info???
- Has thanked: 1129 times
- Been thanked: 3919 times
Re: OLD 4 stroke motor
I can't tell from the pics, is that a rotary valve? I always thought the rotary valve was a great idea as the parasitic drag would be far less. Wonder why it never caught on
Yes, these are rotary valve engines.
I can't answer your question, maybe more difficult to seal properly?
- civilguy
- Has thanked: 5 times
- Been thanked: 14 times
The rotary valves are used on airplane motors all the time, but I think the slide valves are used mainly in car applications as it gives you the most mounting options. The rotaries need the throttle linkage in line with the motor (behind or ahead) or a bellcrank to change the throw direction 90deg. Having the slide simplifies linkage attachment.
Cool old 4 stroke.
Cool old 4 stroke.
Jeff
Jeff
- civilguy
That's what I get for skimming when I'm supposed to be working.gomachv wrote:Not the carb, the valvetrain
Jeff
Jeff
- 1348 Views
Last post by Puffdogg
- 966 Views
Last post by DennisM
- 931 Views
Last post by justinspeed79
- 1343 Views
Last post by WriteDean
- 2051 Views
Last post by uniquenamehere
- 2277 Views
Last post by MelvinsArmy
- 2337 Views
Last post by Dadio
- 703 Views
Last post by joel45acp
