my new runner
my new runner
i took this baby out on the track for the first the other day it wasnt to bad is there any one who can give me sum set up tips i e caster camber suspension spur n pinion. i race on carpet polished floor with jumps .
- Been thanked: 4 times
Re: my new runner
Just a few tips
toe the front wheels in a bit
if the track is small and has tight corners put 30 degree blocks up front. This will help the front wheels lay over a bit when you turn.
if it is a bigger track with more open corners use about 15 degree blocks. This will still lay the wheel over a bit but not as much.
Hope this helps
Hope this helps
- 1536 Views
Last post by Mad Racer
- 1268 Views
Last post by treehugger
- 1706 Views
Last post by slow_jun
- 791 Views
Last post by Tadracket
- 27 Replies
- 3730 Views
Last post by saucisse
- 19 Replies
- 2626 Views
Last post by JPAE07
- 949 Views
Last post by Volumiza
- 1739 Views
Last post by shodog
Users browsing this forum: Tbot [Bot] and 1 guest
