yz10 belt
yz10 belt
i was wondering if anyone had try to fit some other rc belt on a yz10 870c seens the front one is not avalable anymore it as 168 tooths and the rear one has 64 tooths i found that hot bodies have a 3mm 169t and m3 63t or does anyone have tryed somthing els thanks
frank
frank
- JK Racing
- Has thanked: 139 times
- Been thanked: 246 times
Re: yz10 belt
here is a yoke belt
http://cgi.ebay.com/YOKOMO-VINTAGE-YZ10-KEVLAR-FRONT-DRIVE-BELT-ZC-651_W0QQitemZ120368624041QQihZ002QQcategoryZ34061QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Re: yz10 belt
thanks jk nice find but does any other belt fit on them cuz it will always be the same old belt that have like 15 years old new but old hahaha and if i want to race it will have to find more avalable ones
frank
frank
- Been thanked: 10 times
Re: yz10 belt
Belts have standard pitch as long you can get teeth count and pitch you will be able to get belts from 3part manufacturer as i did with lazer belts.
mvh Isobarik
mvh Isobarik
- highwayracer
- Been thanked: 7 times
Re: yz10 belt
In theory, the length of 1 tooth is about 3mm long. This shouldn't be too much of a difference especially if you're using a tensioner on the front. As for the rear, I don't think you can adjust the tension on an 870c...unless you have the rpm rear bulkhead.dubfreak wrote:i was wondering if anyone had try to fit some other rc belt on a yz10 870c seens the front one is not avalable anymore it as 168 tooths and the rear one has 64 tooths i found that hot bodies have a 3mm 169t and m3 63t or does anyone have tryed somthing els thanks
frank
The prices seem pretty resonable for those parts...so the risk isn't too bad.
Regards,
highwayracer
Re: yz10 belt
i do have the rear rpm difcase with adjustment will have to try them and let you know how they fit for the front one i thogh that if it was to long i could use 2 tensioner to tighten them let me know what you think of it.
does someone know where i could find more belts with the spec of them?
thanks frank
thanks frank
- Mr. ED
- Has thanked: 62 times
- Been thanked: 62 times
Re: yz10 belt
You might get away with the one tooth longer for the front and one tooth less for the rear quite easy: isn't your motor mount fixed to the chassis on long holes?
Otherwise, change the height of the tensioner, move it or add a second one.
The hotdog had 2 tensioners also; to guide the belt over the transverse mounted stickpack
Re: yz10 belt
no Mr. ed the motor mount is held in place with 3 screws and the holes in the base plate do not give adjustemt but the rear one i think it still avaleble does some one know where to buy it?
for the front one thats what i alredy thought to put 2 tensioner will see
frank
frank
- Mr. ED
Re: yz10 belt
oops, you're right.
It's the rear bulkheads position that can be adjusted on some chassis for the correct tension on the rear belt
- Mr. ED
Re: yz10 belt
hey Frank,dubfreak wrote:i was wondering if anyone had try to fit some other rc belt on a yz10 870c seens the front one is not avalable anymore it as 168 tooths and the rear one has 64 tooths i found that hot bodies have a 3mm 169t and m3 63t or does anyone have tryed somthing els thanks
frank
Did you try the HPI belts in the end?
- 794 Views
Last post by GJW
- 1119 Views
Last post by smoky
- 2014 Views
Last post by aip47-2008
- 2685 Views
Last post by RichieRich
- 34 Replies
- 3960 Views
Last post by treehugger
- 1724 Views
Last post by buttmonkey1969
- 5322 Views
Last post by Ronbo
- 1166 Views
Last post by Toaster
Users browsing this forum: ongbenghui and 8 guests
