Astute Thorp Dirt Burner
Synergy
Has thanked: 127 times
Been thanked: 72 times
Post by Synergy »
I bought this for my Astute and I guess/hope it's 48DP would that be correct :?:
Dirt Burners.JPG (12.48 KiB) Viewed 1293 times
Here's my TC Showroom
JK Racing
Has thanked: 139 times
Been thanked: 246 times
Re: Astute Thorp Dirt Burner
Post by JK Racing »
If memory serves me right (and I have been wrong a lot)....
Thorp used Kimbrough gears...should be us 48 pitch.
Synergy
Post by Synergy »
Thank you JK, I didn't want to run a 48dp on it if it was 0.6 they're so close in pitch the difference is almost imperceptible (that is until it's all chewed up).
Delorean
Has thanked: 17 times
Been thanked: 14 times
Post by Delorean »
Hey guys. Sorry to bring this back from the dead but what i don't get with these thorp bits is why they're called overdrive or under drive. Every pic I've seen, the counter gear on the back has 16 teeth just like standard. Anyone have any ideas?
Thanks
JK Racing
Post by JK Racing »
Not sure about the astute version, but on the ultima/optima version the inner gear and counter gear were distinct for the underdrive/overdrive sets. You couldnt mix/match at will, but one of them worked with stock (as the one above probably does.
Return to “Tamiya Forum”
