VW body
- a01butal
- Has thanked: 34 times
- Been thanked: 40 times
Re: VW body
I think there have been several threads about the conversion and mrlexan was selling a great VW body and he may have more if not pm me and I can help.
This is all very interesting!
- Has thanked: 36 times
- Been thanked: 1318 times
Re: VW body
the only buggy that i know of that is a direct fit (wheelbase) to the rc10 is the old proline vw, which was discontinued many years ago. any of the others, be it one of jay's repros, or the parma vw body, the chassis will need to be shortened around 3/4" for it to look right.
- murphy3428
Re: VW body
kamtec makes some nice looking bug bodies
- Attachments
- 70_1.jpg (23.24 KiB) Viewed 2946 times
- c4_1.jpg (13.67 KiB) Viewed 2944 times
- 44_1_b.jpg (28.99 KiB) Viewed 2943 times
- 4b84_1.jpg (23.91 KiB) Viewed 2944 times
- a01butal
Re: VW body
The threads I mentioned included details on shortening the wheelbase, and it wasn't to complicated, however these maybe excellent options.
- murphy3428
Re: VW body
You also could use the hpi body which I have here on this tomahawk without needing to shorten your rc10 wheel base is pretty much the same as the tomahawk
- bearrickster
Re: VW body
the parma Body has been discontinued also so if you want one you better get it. theirs a few on E-Bay. VW is not renewing Lic. so no one can make them anymore. Sucks
Re: VW body
Shorten it meaning cut or moving the nose back. If I have to drill and cut I don't want to. This Idea came to me for the powdercoated chasis I have.
scr8p wrote:the only buggy that i know of that is a direct fit (wheelbase) to the rc10 is the old proline vw, which was discontinued many years ago. any of the others, be it one of jay's repros, or the parma vw body, the chassis will need to be shortened around 3/4" for it to look right.
- MelvinsArmy
- Been thanked: 11 times
Re: VW body
RC Chick, I've got a minty black tub and nose shortened 1" for a baja bug conversion, as well as a Tamiya Blitzer Beetle hard shell if your interested. The left over parts from this car that I took apart to build a truck out of:
- Diggley
Re: VW body
I'm sure this may be old news by now,
Proline finally has V Dubb's blessing to start producing Baja bugs, and they're making up for the drought. At last count, they have 4 different models within the last month or so.
There are 2 different Revo sized bodies w/fantastic detail. A long chassis and short chassis version. I checked out one yesterday, it looks like the "short" version will fit my GT perfectly. They're larger than the Tamiya clones, (closer to 1/8th scale) but wow...they're nice.
Proline also just released a 3/4 Beetle (full front fenders) body for the rock crawler crowd. One for the Axial types & one for the Losi Mini Crawler. Both would make interesting alternatives to the normal Sand Scorcher, but are smaller in scale.
The Kamtec worked out perfect on my T3 chassied B2, (RC10 B2.0 Baja project post) I think the wheelbase looks a little better long for the desert style I was going for. The body detail needed a little creative help.
Still, nothing tops Tamiya in the detail department.
If you plan on using a B2, B3, or T3, for you Baja, the stock T3 truck mounts are the way to go. The rears are stock older 10T mounts that just happen to bolt up perfectly between the rear shock strut supports.
As far as a tub chassied RC10, the best mounts I've ever seen were from JG. You may be able to find them on E-Bay.
Another alternative would be buying a sheet of Kydex and making you own. The JG stuff used to form pretty well with a little heat applied.
Hope this helps!
Hope this helps!
Projects and shelfers:
- KvilleKrawler
Re: VW body
Do you think the long revo chassis body would fit a standard RC-10 gold pan?Diggley wrote:I'm sure this may be old news by now,
- Diggley
Re: VW body
**********************************************************************************************KvilleKrawler wrote:Do you think the long revo chassis body would fit a standard RC-10 gold pan?Diggley wrote:I'm sure this may be old news by now,
I think it may come up way too long on a standard unmodified RC10. You'll have a lot of overhang in the front, and the front tires will hit the back of the front fenders. The long version was too much for my GT. (which is way longer than the old school tub RC10)
I'm going with the short version for it...Id bet it would be just right for a 10T also.
The width is right on for a 10th scale Baja.
Proline's website has the specs on all 4, you may want to measure the wheelbase and check out which is best for your project.
- Diggley
Re: VW body
www.prolineracing.comDiggley wrote:**********************************************************************************************KvilleKrawler wrote:Do you think the long revo chassis body would fit a standard RC-10 gold pan?Diggley wrote:I'm sure this may be old news by now,
- Mr. ED
- Has thanked: 62 times
- Been thanked: 62 times
Re: VW body
taken from the proline site, hope they don't mind the free publicity for their latest; 244 mm wheelbase, 1/10 crawler
I think the cleanest way to mount on a goldtub would be to velcro them to the side of the tub? Should be about correct for the width. (Assuming you drop it low enough to cover the tub sides that is)
PS: for a runner it sure is better to use at least one body post in the front and rear in addition to the velcro: to keep the body from swinging over to one side in corners
- shredderboy
Re: VW body
murphy3428-did you mean this HPI VW Body
http://www.philshobbyshop.com/tek9.asp?pg=products&specific=johqdppqi
or this one
http://www.hopupplanet.com/shopcart.asp?pg=products&specific=jnhpfpgmpqq
or the one for the E-Savage?
or this one
5.5T Brushless B4
[youtube]7dBeNEBtFK8[/youtube]
- 1059 Views
Last post by yellowdatsun
- 36 Replies
- 8343 Views
Last post by SluggoV2
- 1099 Views
Last post by GreenBar0n
- 2237 Views
Last post by popboy905
- 952 Views
Last post by tizeye
- 1189 Views
Last post by highwayracer
- 522 Views
Last post by phaze1todd
- 2177 Views
Last post by Seabass
