Schumacher Bosscat "Works" new build
CATS
Post by CATS »
Hi all
Been busy this weekend so thought I would post up pictures of my new built Bosscat works. All parts are new, shell was masked by me but sprayed by airheadgraphics.
Hope you all like
Scott
phoenix
Has thanked: 5 times
Been thanked: 19 times
Re: Schumacher Bosscat "Works" new build
Post by phoenix »
Very nice build you finished there ! Congrats !
minichamps11
Post by minichamps11 »
Top work Scott - that shell looks ace!
CATS
Post by CATS »
thanks for the comments guys, Im very happy with how it all came out :D
minimini
Location: KWS@Hong Kong; 3.5 hours' trip to meet tiger1 and only 7,777 miles from Doug
Been thanked: 11 times
Post by minimini »
what a nice car !!......
as far as I remembered....... I think Boss Cat got two types of chassis........one with 6 battery slots .......another one with 8..........is the "Works" version comes with the one having 6 or 8 ??......
minichamps11
I believe that the standard Bosscat chassis (all versions except the Sport) had 8 cell slots. You could chose whether you ran the cells forwards or backwards, however you had to file lugs off to run the forwards set :x There was also a optional USA Nationals carbon fibre chassis which had just the 6 cell slots, but further forwards than the standard car & it was narrower too. Looking at Scott's photo's I'm guessing the car has a Fibre-lyte chassis fitted, as it looks standard width but with only 6 cell slots.
USA on the left, standard on the right hand side
Finally there was an optional "Team" asymmetric chassis which mounted the cells at an angle to try and get them closer to the centre of the car. I don't think any Bosscat's came with this as standard, not even the "Works" edition. It doesn't leave much material to servo tape your electronics on to!
CATS
Post by CATS »
sounds about right Ian, thanks for clearing it up I was unsure
Scott
minimini
Post by minimini »
minichamps11 wrote:I believe that the standard Bosscat chassis (all versions except the Sport) had 8 cell slots. You could chose whether you ran the cells forwards or backwards, however you had to file lugs off to run the forwards set :x There was also a optional USA Nationals carbon fibre chassis which had just the 6 cell slots, but further forwards than the standard car & it was narrower too. Looking at Scott's photo's I'm guessing the car has a Fibre-lyte chassis fitted, as it looks standard width but with only 6 cell slots.
many thanks !!.........
for the optional asymmetric chassis...........stick a small lexan sheet onto the chassis so that you can have an area to servo tape the electronics........ :)
Return to “Schumacher Forum”
