RC10 springs?
General info, Q&A.
ThomasH
RC10 springs?
Post by ThomasH »
I am looking for a selection of springs to try. Are these the correct springs for the stock works shocks?
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXBVF9&P=K
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXBVG0&P=K
Thanks
carloco8
Has thanked: 74 times
Been thanked: 271 times
Re: RC10 springs?
Post by carloco8 »
Yup, those are all you'll need. General set up will be between green and silvers all around. On a smooth high-bite track with modern tires, blues may help if you experience traction-roll problems. Gold and reds are on the extreme side of hard springs for buggies, but hey you never know. Have fun testing :D
ThomasH
Re: RC10 springs?
Post by ThomasH »
Thank you for your help carloco8 :D
flipwils11
Been thanked: 19 times
Re: RC10 springs?
Post by flipwils11 »
Bumping an old thread after I found this in the searches.
Will these springs work on my stock gold pan RC10 shocks (gold shocks)? The silver springs it has are causing the ass to sag a lot. :oops: I have 30w oil and the spring collar down pretty far and they are still pretty overmatched.
SteveK
Re: RC10 springs?
Post by SteveK »
Those springs will definitely fit the rear. The fronts might be too long if you have the .56" shocks. If you have the longer front shocks, those will fit fine too.
How old are the silver springs you have now? They might have lost some of their tension if they are older.
flipwils11
Re: RC10 springs?
SteveK wrote:Those springs will definitely fit the rear. The fronts might be too long if you have the .56" shocks. If you have the longer front shocks, those will fit fine too.
I'm guessing they are original to the car.
civilguy
Has thanked: 5 times
Been thanked: 14 times
Re: RC10 springs?
Post by civilguy »
The 550 can you now have in the back of that thing isn't helping matters. :wink:
The blue ones may work for you.
Jeff
