Hello, I just picked up a nice gold tub with a early stealth tranny. If I am not mistaken, if you have a slipper then it is a stealth tranny right? Also the internal drive ration for all RC10 stealth tranny prior to the changing the buggy is 2.25:1, right?
I plan on racing it at my local track, and running it i the stock class. GTB, 13.5 motor. Will the tranny handle this? SHould I update anything? I was told I can run a modern slipper with this tranny. Has anyone done this?
Any help or advice will be greatly appreciated.
New RC10 buggy for me. Have questions need some advise.
- Has thanked: 36 times
- Been thanked: 1318 times
Re: New RC10 buggy for me. Have questions need some advise.
yes, the original stealth is a 2.25.
you can use the complete topshaft/slipper setup from the b4. or, you could just get a complete b3/t3 slipper assembly. they're a little larger in diameter than the slipper on the 2.25 stealth.
Thank you.
So is the B4 slipper assembly is a worth while upgrade?
- 1110 Views
Last post by teman
- 987 Views
Last post by bscotti
- 1287 Views
Last post by Asso_man!
- 980 Views
Last post by yellowdatsun
- 703 Views
- 2240 Views
Last post by askbob
- 800 Views
Last post by aconsola
- 1624 Views
Last post by morpheus2010
