If I wanted to tune down the speed of a motor, can I use the Throttle EPA adjustment to do it??
Or would it have to be the EXP adjustment??
I want to use my 5.5 on the T4, but gearing it down can hurt the ESC, and running it as is, it's too much to handle in a small track like RCHR.
Can I tune it down using the EPA adjustment??
Thank you.
Tunning EPA or EXP on a radio, Airtronics M8!!!!!
- Has thanked: 19 times
- Been thanked: 29 times
- loneranger
- Regular Member
Re: Tunning EPA or EXP on a radio, Airtronics M8!!!!!
Yes, I use this all the time if I have a motor that's too fast for the track. With rubber tires I turn down the EPA down to the point where the tires stop ballooning. Just be sure to check the ESC heat sink after a few minutes to make sure it doesn't get too hot.
EXP is for setting how sensitive the throttle is around neutral.
Tom Loranger
http://www.18thScaleRacing.com
- carloco8
- Has thanked: 74 times
- Been thanked: 271 times
+1loneranger wrote:Yes, I use this all the time if I have a motor that's too fast for the track. With rubber tires I turn down the EPA down to the point where the tires stop ballooning. Just be sure to check the ESC heat sink after a few minutes to make sure it doesn't get too hot.
Between the EPA and perhaps different gearing, you essentially have a 5.5, 6.5, 7.5, 8.5, etc.....
This way, when you dial it down and if the power curve is too short, you can slightly gear up!
I ran the truck this weekend with the 5.5 and turned the EPA down to 70% and she was a beast out there, now it's on to acquiring a Lipo pack and I'll have my race truck set up properly.
- 1673 Views
Last post by maruirc
- 1333 Views
Last post by tbfoto
- 2431 Views
Last post by Momo5
- 2501 Views
Last post by juicedcoupe
- 1334 Views
Last post by carloco8
- 2278 Views
Last post by aakoskin
- 916 Views
Last post by AndrewSi
- 2035 Views
Last post by jonboy
